Smoking deal for someone looking for a easy drop in and go motor. I am only removing because I am switching to a 6.
-this is in my car now and I can test drive or send video clips if shipped-
Car is fast and always starts, I have all the receipts. *if you have a 6 we can work a different deal*
$3,000 cash or paypal(you pay fee)
1.7 case(ea) with 2.0 pistons
-t4 cam .415x278 for carbs
-crank
-full rebuild 2001
-911 valve adj. lock nuts
-Mallory Unilite distributor
-Hyfire VI-AL ignition system
-Bosch blue coil
-Summit racing breather tank-oil-
-oil temp sensor
-*2011 CFR did pushrod seals.
-CB Performance 3.5lbs fuel pump and filter
-Dual Weber 44idf recent rebuild.
-New Tangerine Racing carb linkage/cables
-4-1 Kerry Hunter header to Supertrapp muffler and I can give you my older setup which was heat exchanger minus the heat to a Bursch muffler-removed last month, and I can give you heat exchangers I have had sitting at the shop.
*no leaks at all*
*recent valve adjust*
** so you get engine, carbs, fuel pump, exhaust, ignition, etc., everything you need to run!
301.213.5101 Chris
