Rear window engine rubber |
Ian Stott |
May 4 2015, 05:19 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Is there an OEM rubber? The rear window is getting replaced and that seal between the window and the rear deck is in bad shape.
Ian Stott Moncton Canada |
May 4 2015, 05:24 PM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm pretty sure 914rubber has that one ...
(IMG:style_emoticons/default/idea.gif) |
Shadowfax |
May 4 2015, 05:40 PM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Ian Stott |
May 4 2015, 05:41 PM
I have that one and it seemed kinda narrow, is it supposed to be narrow?
Shadowfax |
May 4 2015, 05:43 PM
Mikey914 |
May 4 2015, 06:36 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the dimensions are the same as OEM. The only difference is the internal clip. Mine will not rust, and you can remove a little of the ends to accommodate any crud that may have accumulated.
Mark |
Ian Stott |
May 4 2015, 11:29 PM
Yes the dimensions are the same as OEM. The only difference is the internal clip. Mine will not rust, and you can remove a little of the ends to accommodate any crud that may have accumulated. Mark How wide is the rubber and what makes it attach? The one I removed had metal in it and was almost an inch wide? Ian |
Mikey914 |
May 5 2015, 12:15 AM
Not quite sure I understand the question. The piece this clips onto on the body is about 3/16". The overall profile is about an inch. There is an internal clip that is bonded into the rubber profile. You can remove a short section of the internal clip if you want to allow any additional clearance on the ends.
Ian Stott |
May 5 2015, 12:41 AM
Not quite sure I understand the question. The piece this clips onto on the body is about 3/16". The overall profile is about an inch. There is an internal clip that is bonded into the rubber profile. You can remove a short section of the internal clip if you want to allow any additional clearance on the ends. I think I have the wrong piece! No wonder it doesn't seem right! Do I have to wait for the correct piece before I put the window back in? Ian |
Mikey914 |
May 5 2015, 01:11 AM
No,
The window actually is independent of the rubber for the decklid. The little lip that sticks into the engine compartment area is what it clips onto. |
Ian Stott |
May 5 2015, 02:45 AM
No, The window actually is independent of the rubber for the decklid. The little lip that sticks into the engine compartment area is what it clips onto. Do you have my billing data? If you do would you send the proper rubber to Chris Foley at Tangerine Racing with my name on it, I'm going down ther in 2 weeks. Thx for your help on this. Ian |
Mikey914 |
May 5 2015, 02:51 AM
I do not retain customer payment info, sorry. But if you can process on the site my assistant can ship tomorrow.
They are right here - http://shop.914rubber.com/Engine-deck-lid-...m?categoryId=-1 Thanks, mark |
Ian Stott |
May 5 2015, 10:37 AM
I do not retain customer payment info, sorry. But if you can process on the site my assistant can ship tomorrow. They are right here - http://shop.914rubber.com/Engine-deck-lid-...m?categoryId=-1 Thanks, mark Done, thx Ian |
Lo-Fi Version | Time is now: 13th May 2024 - 03:08 AM |
