The two wheel lift ..., Anything i can do about that? |
May 4 2015, 11:09 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Going through some of my pictures, i started to wonder if there is something i can do about this?
(IMG:style_emoticons/default/idea.gif) |
McMark |
May 5 2015, 12:05 AM
Some thoughts I pulled out of my hair:
Lower CG- either by moving weight down, or moving the whole car down. Stiffer suspension- you obviously have a nice F/R balance, make everything harder to keep the weight from shifting towards the outside. Apparently it only does it when you're turning right. (IMG:style_emoticons/default/poke.gif) |
May 5 2015, 10:45 AM
Apparently it only does it when you're turning right. (IMG:style_emoticons/default/poke.gif) Doh! Then all i need is a 220lbs passenger and i should be fine ... (IMG:style_emoticons/default/biggrin.gif) |
Randal |
May 5 2015, 11:55 AM
Apparently it only does it when you're turning right. (IMG:style_emoticons/default/poke.gif) Doh! Then all i need is a 220lbs passenger and i should be fine ... (IMG:style_emoticons/default/biggrin.gif) Questions: What springs are you running? Are you running a limit slip differential? |
May 5 2015, 07:39 PM
What springs are you running? Are you running a limit slip differential? 200lbs rear springs, stock 911 19mm torsion bars upfront, front and rear swaybar, Koni adjustable shocks on full hard for the track, no LSD (yet). (IMG:style_emoticons/default/idea.gif) PS: Keep in mind, this car gets mostly driven on the street, i don't want to go full race for the suspension. All the images were taken at the track with the Konis set to full hard. |
ThePaintedMan |
May 6 2015, 06:29 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Those runs are on slicks right?
Also, the rear swaybar has an impact, probably fairly significantly with slicks. It's probably the biggest reason why the rear is off the ground. With slicks and without bigger torsion bars, I bet that the front is probably always going to lift. |
May 6 2015, 10:34 AM
Those runs are on slicks right? Also, the rear swaybar has an impact, probably fairly significantly with slicks. It's probably the biggest reason why the rear is off the ground. With slicks and without bigger torsion bars, I bet that the front is probably always going to lift. GoodYear R250 slicks. The chassis doesn't twist much with the cage and all so usually the whole side of the car just comes up. It happens quite often at AX and can be somewhat scary. I'm just afraid i'm gonna flip it over one of these days. (IMG:style_emoticons/default/unsure.gif) |
sbsix |
May 6 2015, 12:43 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 449 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Andy, it's been my experience that running a rear sway bar without a LSD will cause the inside front wheel to lift in a tight corner, running shaved tires. No experience with slicks to comment on.
ChrisFoley |
May 6 2015, 02:28 PM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This issue is related to roll centers.
If the CG is above the roll center, the car will have a greater tendency to tip in a corner. On a lowered 914, the front roll center may even be below ground, but the rear roll center is probably well above the CG. |
naro914 |
May 6 2015, 03:29 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
What Chris said...
fyi, I don't run a rear sway in either of our cars and never have rear lift. I kept trying it, and it handled horribly, so I took them off both cars.. Forget Papa Smurf because full race set up, but with Huey we have 180# rear and biggest (21mm??) front torsion we could find, with a Weltmeister front sway bar. The most anyone has ever seen of front lift is relatively minor..both with Hoosier A6 |
Randal |
May 6 2015, 05:33 PM
What springs are you running? Are you running a limit slip differential? 200lbs rear springs, stock 911 19mm torsion bars upfront, front and rear swaybar, Koni adjustable shocks on full hard for the track, no LSD (yet). (IMG:style_emoticons/default/idea.gif) PS: Keep in mind, this car gets mostly driven on the street, i don't want to go full race for the suspension. All the images were taken at the track with the Konis set to full hard. I couldn't keep 222 on the ground with less than 240# springs in back. Also I never ran a rear sway bar after several people, that know what they are talking about, told me they didn't work. You have a bunch more weight in the back than I did, so thinking you might even nead heaver springs. Easy to swap out your springs where ever you want to race. Also if the front lifts less without the sway bar hooked up and with heavier springs you know your going the right direction. Ask around and borrow a set of 300#ers and give it a try. I'd also call Bontempi and ask what springs the 3.6 they build had in her. |
john914somers |
May 7 2015, 05:25 AM
Member Group: Members Posts: 59 Joined: 24-January 12 From: sacramento Member No.: 14,051 Region Association: Northern California |
Going through some of my pictures, i started to wonder if there is something i can do about this? (IMG:style_emoticons/default/idea.gif) What kind/size sway bar up front? |
May 7 2015, 10:52 AM
Going through some of my pictures, i started to wonder if there is something i can do about this? (IMG:style_emoticons/default/idea.gif) What kind/size sway bar up front? An early Tarett prototype bar, it's hollow and supposed to be the equivalent of a 21mm bar. (IMG:style_emoticons/default/smile.gif) |
Andyrew |
May 7 2015, 01:52 PM
I cant remember if I have 275's or 225's in the car right now... I might have a set of 275 12"ers that you can test out. They wont let you go that low though, I believe I swapped them out so I could run a hair lower.
Or you could just grab some new ones.. http://www.summitracing.com/search/departm...Order=Ascending |
J P Stein |
May 7 2015, 01:59 PM
I lifted the inside front regular like, but never got up on 2 (as far as I know).
21 mm front T bars, the same tarret bar as And, no AR bar in back with 275ls springs in back.....on slicks. I don't know the answer but I suspect your suspension is too soft for slicks & your ride height is too high. |
Downunderman |
May 7 2015, 02:00 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
I suspect that the shocks screwed up to full hard are acting as springs. Wind them right back and see what happens.
Randal |
May 8 2015, 11:15 AM
yeahmag |
May 8 2015, 11:22 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I have some 275# 2.25" rear springs you can try if you like. I'm running 225# rears with 21mm front torsion bars and a 19mm roll bar.
naro914 |
May 9 2015, 07:49 AM
Honestly Andy I don't think there's a way to fix this, its done. I'll take it off your hands and relieve you of the stress of such an awful car...
Lo-Fi Version | Time is now: 7th May 2024 - 01:33 PM |
