Have you broken the targa clips in the trunk |
zambezi |
May 5 2015, 11:32 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
A while back I had the targa top stowed in the trunk and needed to get something from underneath it. I thought to myself.... I can get it out from underneath without completely removing the targa. I will just be carefull and pick it up just enough to get the item out. Then ... snap! The clip broke. Has that happened to anyone else?
Tom_T |
May 5 2015, 11:38 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Old clips get brittle, but the trick is to slide it a 1/4-1/2" forward & lift.
Porsche actually designed them to do just what you are trying to do. TT (IMG:style_emoticons/default/beerchug.gif) /////// |
zambezi |
May 5 2015, 11:40 AM
So I came up with my version of a solution. I made the clips pivot.
I used a 1 inch stainless piano hinge. 3 inch long piece on each one. I drilled the holes to match the car being sure that the hinges are in alignment with each other on each side. The hinges are secured through the original holes with #8 x 32 x 1/2 inch long countersunk machine screws. The new targa clips are then riveted to the hinge using 3/16 x 1/4 inch pop rivets and a rivet washer on each one. It all works as I envisioned and will now allow me to access the trunk without lifting the targa completely out of the trunk. This is how it should have been designed from the beginning. |
zambezi |
May 5 2015, 11:41 AM
zambezi |
May 5 2015, 11:42 AM
zambezi |
Johny Blackstain |
May 5 2015, 11:45 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Yep, I broke one. The clip is still available, but the hard part is finding a matching rivet. Most people give up & just bolt the new one in, which is what I would do if originality didn't matter so much. In the pic below the new one is on the left & can clearly be distinguished from the original one on the right. They do get old, yellow & brittle.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 09:53 AM |
