How to remove the headlight mechanism, Is there a good replacement for the bristles on lift bar opening? |
913B |
May 5 2015, 08:44 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Any help is appreciated to direct me to the right thread. I want to disassemble and replace the plastic bushings for the headligh pivots. What is the 13mm nut and bolt (i think its 13) directly behind the headlight for, looks like it is attached the headlight pivot bar.
Thanks in advance always. |
altitude411 |
May 5 2015, 09:12 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
toolguy |
May 6 2015, 07:09 AM
That could be the stop positioner. . keeps the headlight assembly from jiggling when you are driving with the headlights on. Otherwise the headlight beams wiggle with every bump.
EdwardBlume |
May 6 2015, 07:37 AM
The assembly sits on the adjustable bolt coming in from the back. If you take it off, note its position.
913B |
May 6 2015, 08:49 AM
Ok I figured out how to remove it sitting in my garae last night.
The new question is the bristles on the lever lift bar opening on the body, is there a good replacement or subsitute for this ?? |
Kansas 914 |
May 6 2015, 10:28 AM
Ok I figured out how to remove it sitting in my garae last night. The new question is the bristles on the lever lift bar opening on the body, is there a good replacement or subsitute for this ?? (IMG:style_emoticons/default/popcorn[1].gif) I need to freshen up that piece on my Willow Green as well... |
913B |
May 6 2015, 10:40 PM
Here is a pic of the bristle/brush/horse hair, or whatever you call it that I am talking about, anyone ?? (IMG:style_emoticons/default/confused24.gif)
altitude411 |
May 6 2015, 11:19 PM
Lo-Fi Version | Time is now: 11th May 2024 - 02:09 PM |
