Need Raby 9590 cam info |
Frank S |
May 6 2015, 04:53 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi there,
I'm about to order parts for my engine rebuild. The plan is to upgrade a 2.0 GA D-Jet engine as following: 2056cc Stroke 71mm (stock) CR 9:1 Raby 9590 cam SSI Heatexchangers Original Muffler The only thing stoping me right now is that I need verify CO2 emissions every 2 years here in Germany. My questions are now: 1. Does this set up idle well and stable at 900-950RPM 2. Does it reach the 3% CO2 spec. in idle I know that a none stock cam should not idle so low, this will be just for the time of the measurement. Without reaching this spec values I not able to register the car here in Germany :-( Thanks and best Regards, Frank |
euro911 |
May 7 2015, 03:54 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Not sure how different the profile is on the 9590 (IMG:style_emoticons/default/confused24.gif) … I have the 9580, and it's either 9:1 or 9.5:1 (I don't recall what CR Richard built it at).
He had me source a Bosch VJR 4 BR 8 (36HP bus/356 dizzy) to provide an optimum advance curve. It idles fine at 900~1000, but I'm still getting a little bog-down at WOT. Need to analyze and re-jet for the new banana muffler (IMG:style_emoticons/default/dry.gif) One thing's for sure - it wouldn't pass a smog test. Glad it's exempt (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:37 AM |
