Need Raby 9590 cam info |
Frank S |
May 6 2015, 04:53 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi there,
I'm about to order parts for my engine rebuild. The plan is to upgrade a 2.0 GA D-Jet engine as following: 2056cc Stroke 71mm (stock) CR 9:1 Raby 9590 cam SSI Heatexchangers Original Muffler The only thing stoping me right now is that I need verify CO2 emissions every 2 years here in Germany. My questions are now: 1. Does this set up idle well and stable at 900-950RPM 2. Does it reach the 3% CO2 spec. in idle I know that a none stock cam should not idle so low, this will be just for the time of the measurement. Without reaching this spec values I not able to register the car here in Germany :-( Thanks and best Regards, Frank |
Dave_Darling |
May 6 2015, 11:13 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The only 914s that require testing in CA any more are the 76es.
--DD |
SirAndy |
May 7 2015, 12:50 AM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The only 914s that require testing in CA any more are the 76es. --DD (IMG:style_emoticons/default/confused24.gif) |
worn |
May 7 2015, 07:33 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The only 914s that require testing in CA any more are the 76es. --DD (IMG:style_emoticons/default/confused24.gif) You mean that the poster is being tested in Germany not California? |
Dave_Darling |
May 8 2015, 10:02 AM
SirAndy |
May 8 2015, 10:19 AM
No, I mean that the CA guys don't actually have much experience with getting the 9500-series cams past the sniffer test. Because very few 914s actually have to pass those. Ok, now your post makes sense. You could have said that the first time around ... (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:36 PM |
