Need Raby 9590 cam info |
Frank S |
May 6 2015, 04:53 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi there,
I'm about to order parts for my engine rebuild. The plan is to upgrade a 2.0 GA D-Jet engine as following: 2056cc Stroke 71mm (stock) CR 9:1 Raby 9590 cam SSI Heatexchangers Original Muffler The only thing stoping me right now is that I need verify CO2 emissions every 2 years here in Germany. My questions are now: 1. Does this set up idle well and stable at 900-950RPM 2. Does it reach the 3% CO2 spec. in idle I know that a none stock cam should not idle so low, this will be just for the time of the measurement. Without reaching this spec values I not able to register the car here in Germany :-( Thanks and best Regards, Frank |
Highland |
Oct 27 2015, 05:29 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Is everyone else running a programmable ignition controller when using the rat 9590 with d-jet?
Would I need to purchase something like an MSD 6A to use a RAT 9590 cam? |
Jake Raby |
Oct 28 2015, 10:31 PM
Is everyone else running a programmable ignition controller when using the rat 9590 with d-jet? Would I need to purchase something like an MSD 6A to use a RAT 9590 cam? Absolutely not. Most have stock distributors, set up as factory, or with DIY modified advance limitations. I know of no one using an external gadget like you mention with the 9590, or the 9550 camshafts. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:52 AM |
