Need Raby 9590 cam info |
Frank S |
May 6 2015, 04:53 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi there,
I'm about to order parts for my engine rebuild. The plan is to upgrade a 2.0 GA D-Jet engine as following: 2056cc Stroke 71mm (stock) CR 9:1 Raby 9590 cam SSI Heatexchangers Original Muffler The only thing stoping me right now is that I need verify CO2 emissions every 2 years here in Germany. My questions are now: 1. Does this set up idle well and stable at 900-950RPM 2. Does it reach the 3% CO2 spec. in idle I know that a none stock cam should not idle so low, this will be just for the time of the measurement. Without reaching this spec values I not able to register the car here in Germany :-( Thanks and best Regards, Frank |
914work |
Oct 30 2015, 08:39 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Now THAT'S useful information.
toon1 |
Oct 30 2015, 08:52 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Now THAT'S useful information. I'm running megasquirt so I can control the Timing and fueling. I am just now starting to realize how much of a benefit this is for these engines.unfortunately my poor little 1.7 has been the abused sacrifice of my FI learning curve. |
914_teener |
Oct 30 2015, 09:10 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Now THAT'S useful information. I'm running megasquirt so I can control the Timing and fueling. I am just now starting to realize how much of a benefit this is for these engines.unfortunately my poor little 1.7 has been the abused sacrifice of my FI learning curve. I am more in line with the original post. I have been looking at this cam for a while for a 2056 with stock injection. Geoff (Bleyseng) says it requires some adjustment of the MPS. I'll assume he is running a stock distributor. His feedback is very positive. I think it is almost mandatory to have a CHT gauge and AFR gauge or instrumentation for tuning. All I have left to do is choose the cam. |
Lo-Fi Version | Time is now: 18th May 2024 - 04:24 AM |
