Need Raby 9590 cam info |
Frank S |
May 6 2015, 04:53 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi there,
I'm about to order parts for my engine rebuild. The plan is to upgrade a 2.0 GA D-Jet engine as following: 2056cc Stroke 71mm (stock) CR 9:1 Raby 9590 cam SSI Heatexchangers Original Muffler The only thing stoping me right now is that I need verify CO2 emissions every 2 years here in Germany. My questions are now: 1. Does this set up idle well and stable at 900-950RPM 2. Does it reach the 3% CO2 spec. in idle I know that a none stock cam should not idle so low, this will be just for the time of the measurement. Without reaching this spec values I not able to register the car here in Germany :-( Thanks and best Regards, Frank |
Jake Raby |
Oct 30 2015, 05:18 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
For sea level operation the 9550 and 9590 should be kept to 8.5:1 max static CR. I have ran them at higher elevations with as much as 9:1, but never more than that.
Lo-Fi Version | Time is now: 18th May 2024 - 05:39 AM |
