Need Raby 9590 cam info |
toon1 |
Oct 30 2015, 03:36 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I've ordered all the parts I need for the rebuild and the last open question I have is: What is the optimum CR for 9590 if I build up the 2056 from 2.0 D-Jet for a 914. Once Jake reported very good results with a 9560 cam and a CR of 8.8 : 1 and I'm not sure if I should go for CR of 9 : 1 with my build. Any recommendations? Thanks, Frank In for an answer also.....I will be doing a build in a few months and 9:1 comp is what I'd like to run |
914_teener |
Oct 30 2015, 04:43 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I've ordered all the parts I need for the rebuild and the last open question I have is: What is the optimum CR for 9590 if I build up the 2056 from 2.0 D-Jet for a 914. Once Jake reported very good results with a 9560 cam and a CR of 8.8 : 1 and I'm not sure if I should go for CR of 9 : 1 with my build. Any recommendations? Thanks, Frank In for an answer also.....I will be doing a build in a few months and 9:1 comp is what I'd like to run I think Bleyseng (Geoff) also posted that it was optimum just below 9:1. I too...am interested in that info as well. |
Jake Raby |
Oct 30 2015, 05:18 PM
For sea level operation the 9550 and 9590 should be kept to 8.5:1 max static CR. I have ran them at higher elevations with as much as 9:1, but never more than that.
914_teener |
Oct 30 2015, 08:15 PM
toon1 |
Oct 30 2015, 08:20 PM
Frank S |
Nov 2 2015, 12:18 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Thanks Jake,
that was the last piece of info needed! |
Lo-Fi Version | Time is now: 4th May 2024 - 06:54 AM |
