Where does this connect to ? |
porschefile2010 |
May 6 2015, 02:00 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
Hi to you all up there. I recently replaced my FI wiring loom and must have knocked this small tube off in the process and I am baffled as to where it should be going> So it's the one coming up through the bottom of the engine bay and adjacent to the water drain, below the battery. I had a feeling it might be coming from the fuel tank as some sort of vent but that seems a long way to be running a vent line.
I know someone here will know straight off where this should hook up. Thanks Richard |
type47 |
May 6 2015, 02:23 PM
Not a factory item so anybodies guess (if you're referring to the plastic looking tube going down to the grommet in the engine shelf). Battery vent? Pressure tube for a mechanical oil pressure gauge?
porschefile2010 |
May 6 2015, 02:30 PM
Thanks Jim. Maybe it is do to with oil pressure. It's a very small gauge tube and quite stiff and inflexible. I'll check the other end out and see if it appears behind the centre console.
type47 |
May 6 2015, 04:12 PM
If it goes through the tin from above ( as it obviously does in the pic) look around the distributor for the oil pressure sender and see if there is provision for tapping off a fitting for the tube for a mechanical gauge. The tube under the tin might go to the center tunnel with the wiring harness. 'Course I shoulda asked first: do you have an oil pressure gauge? (IMG:style_emoticons/default/idea.gif)
ejm |
May 6 2015, 04:35 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
That thin plastic tube is the vent from the fuel tank. It goes to the carbon canister which would be in the engine compartment on your '75
rgalla9146 |
May 6 2015, 07:17 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
ejm nailed it
JeffBowlsby |
May 6 2015, 08:32 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Agree. It connects to the charcoal canister...or did.
porschefile2010 |
May 7 2015, 03:37 AM
Thanks everyone. The emissions gear had been taken out by a PO before I brought it down from LA so I might as well get rid of it I guess. I had a feeling I had seen something about there being a vent somewhere but couldn't find any reference in my Haynes manual. Mind you I find the index in the Haynes manual a bit weird too.
euro911 |
May 7 2015, 04:08 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
My '75 doesn't have a charcoal canister either … I just ran the tubing out into the r/r wheel well.
Lo-Fi Version | Time is now: 20th May 2024 - 09:53 AM |
