Speedometer Removal, Speedometer Removal |
Hinterleiter |
May 8 2015, 06:28 AM
Newbie Group: Members Posts: 6 Joined: 24-September 04 From: Philadelphia, PA Member No.: 2,823 |
I need to remove the speedometer from my 1974 2.0 in order to repair the odometer. Pulled the gauge plate and for the life of me, getting the speedometer out has me beat. Looked at assembly drawings, reviewed several manuals and I can not figure out how to remove the speedo from the plate. Got to be an easy way that I'm missing. Help!
May 8 2015, 06:54 AM
914-6 GT in waiting Group: Members Posts: 19,262 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Pull it out. Just held in with the rubber trim ring. (once the odometer cable is set free)
dcecc1968 |
May 8 2015, 06:58 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
All the guages in my 914 are held in place by friction from a rubber ribbed sleeve. if you have the plate off, you should be able to just push them out.
rgalla9146 |
May 8 2015, 07:28 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Re-attach the "gauge plate" with the four phillips screws
Slip a flat screwdriver under the edge of the speedo and lever it out of the plate. Move the screw driver from place to around the edge of the gauge. They can be very stuck in place. |
May 8 2015, 10:05 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Or just push it out from the back side of the gauge. It's a bit of a reach with the gauge plate installed, but very doable.
Note that you'll want to unplug and label all of the wires, and unhook the speedo cable and the trip odometer reset cable. --DD |
Lo-Fi Version | Time is now: 12th May 2024 - 07:57 PM |
