Quick Question, Will they fit? |
ericoneal |
May 8 2015, 11:39 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
15x6 mini-lite rims. 205/50 tires.
Will these just bolt on (non-flared), or will I need spacers, etc? Thanks |
Mueller |
May 8 2015, 11:44 AM
offset?
May 8 2015, 11:46 AM
914-6 GT in waiting Group: Members Posts: 19,267 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've heard they fit great but I have no personal experience
ericoneal |
May 8 2015, 01:13 PM
Thanks. Seller says they will bolt right on.
eric9144 |
May 8 2015, 03:46 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
They're usually 6.5" wide, have seen several sets on cars--all stock narrow body and no "pulling" was needed. If you can try to mount before committing, aka try before you buy. They look sweet! Good luck!
May 8 2015, 05:25 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It's a definite maybe. The wheels do bolt on, but there is usually some rubbing aft of the shock tower on the inner front fender when the steering wheel is turned full lock. And there is often, but not always, some rubbing on the fender lip of one rear fender or the other. You may need to pull the fender a bit for clearance.
--DD |
tomrev |
May 8 2015, 06:35 PM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
I ran them back in the day on my six; the 6 1/2 in by 15 in. version, with 195/50 Yoko's. Plenty of room, even on the track, with stock fenders that had the inner edges rolled, and flattened a bit like we all have done. Nice wheels too!
914Sixer |
May 8 2015, 07:56 PM
I would TEST fit them and drive them. It has been noted over the years that there is a lot of difference from side to side on these cars.
Lo-Fi Version | Time is now: 13th May 2024 - 09:54 AM |
