Big bore 2.6, Would you do it? |
jesiv |
May 9 2015, 02:05 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I am developing my strategy for restoring my 1975 1.8. I am thinking I will have it repainted to match so not thinking of doing the trunks or door jams. Will I regret this?
Instead of rebuilding the 1.8, I am thinking of keeping the stock 1.8 with FI and having a new big bore 2.6 built. Thus when/if I sell I will have the original engine with a stock car. Will use the car for weekends and some ax Thoughts?? Regards James |
May 9 2015, 02:16 PM
Do it
GeorgeRud |
May 9 2015, 03:44 PM
You can always do the trunks later, but I'd recommend doing the door jambs or you'll notice the differences. As far as the engine, keeping the original is probably a good idea.
JoeDees |
May 11 2015, 08:32 AM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
You will want to paint the door jambs. Trunks and stuff can pass, but the door jambs will bug you if you don't paint them.
rhodyguy |
May 11 2015, 08:41 AM
2.6 type 4? Bring money and lots of it.
crash914 |
May 11 2015, 10:33 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
to do it right, plan on around $12K for the motor...good luck!
Jake Raby |
May 11 2015, 01:25 PM
crash914 |
May 11 2015, 05:33 PM
You might be right, but that's about what I got in mine...in 2003 $$ though..
Jake Raby |
May 11 2015, 07:22 PM
Mueller |
May 12 2015, 12:42 PM
Would this be just bigger bores or a combination of longer stroke to get the 2.6 liters?...
crash914 |
May 12 2015, 01:07 PM
mine is 103mm cylinders by 80mm stroke.
see picture on the left |
jesiv |
May 13 2015, 10:58 AM
So I am being told now that I should go with a 2.4 as it will be a much more stable platform than the 2.6. Is this a distinction without a difference??
May 13 2015, 12:47 PM
2.4 is 103MM pistons and stock crank of 71mm
Not sure who might be advising you, but for a while welded and recut cranks were a problem due to the oil galley becoming too close to the journal...and it would crack and break. We now can buy new cranks from DPR crankshafts....so that issue seems to be less troublesome. Rich |
rhodyguy |
May 13 2015, 01:07 PM
forget heat. in all likelihood, you need to plan which header and muffler system you intend to run. what's your fuel supply system plan? carbs, dual throat throttle body f.i.? ignition? what's the cylinder budget? it's a whole lot more than just displacement.
jesiv |
May 13 2015, 01:14 PM
I am planning carbs. I really want heat. I want the car to be drivable e.g. Drive from San Francisco to Los Angels.
crash914 |
May 13 2015, 01:50 PM
Best bet is a 2056. Then just driv3 it. Best bang for the $.
nine9three |
May 13 2015, 02:26 PM
Member Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest |
Not to hijack this thread, but I'm seriously thinking 2270. Seems to be a lot of write-up on this displacement, and it matches what I would like to get in terms of H.P. I'm making an assumption here but the larger the displacement the more critical the components needed to equal reliability.
jesiv |
May 13 2015, 02:29 PM
Yeah but looking for more power. It's hard to go from a boxster to the 914. I am keeping the 1.8 for originality. This engine is all about power and fun :-)
May 13 2015, 02:53 PM
So a 2.4 with heat exchangers
jesiv |
May 13 2015, 03:07 PM
I assume that's what you would do... Other options??
Lo-Fi Version | Time is now: 14th May 2024 - 04:20 PM |
