jesiv
May 9 2015, 02:05 PM
I am developing my strategy for restoring my 1975 1.8. I am thinking I will have it repainted to match so not thinking of doing the trunks or door jams. Will I regret this?
Instead of rebuilding the 1.8, I am thinking of keeping the stock 1.8 with FI and having a new big bore 2.6 built. Thus when/if I sell I will have the original engine with a stock car.
Will use the car for weekends and some ax
Thoughts??
Regards
James
r_towle
May 9 2015, 02:16 PM
Do it
GeorgeRud
May 9 2015, 03:44 PM
You can always do the trunks later, but I'd recommend doing the door jambs or you'll notice the differences. As far as the engine, keeping the original is probably a good idea.
JoeDees
May 11 2015, 08:32 AM
You will want to paint the door jambs. Trunks and stuff can pass, but the door jambs will bug you if you don't paint them.
rhodyguy
May 11 2015, 08:41 AM
2.6 type 4? Bring money and lots of it.
crash914
May 11 2015, 10:33 AM
to do it right, plan on around $12K for the motor...good luck!
Jake Raby
May 11 2015, 01:25 PM
QUOTE(crash914 @ May 11 2015, 08:33 AM)
That won't really even buy all the components these days.
Its a good starting point, though.
crash914
May 11 2015, 05:33 PM
You might be right, but that's about what I got in mine...in 2003 $$ though..
Jake Raby
May 11 2015, 07:22 PM
QUOTE(crash914 @ May 11 2015, 03:33 PM)
Nothing is the same today.... Back then good parts existed off the shelf.
Mueller
May 12 2015, 12:42 PM
Would this be just bigger bores or a combination of longer stroke to get the 2.6 liters?...
crash914
May 12 2015, 01:07 PM
mine is 103mm cylinders by 80mm stroke.
see picture on the left
jesiv
May 13 2015, 10:58 AM
So I am being told now that I should go with a 2.4 as it will be a much more stable platform than the 2.6. Is this a distinction without a difference??
r_towle
May 13 2015, 12:47 PM
2.4 is 103MM pistons and stock crank of 71mm
Not sure who might be advising you, but for a while welded and recut cranks were a problem due to the oil galley becoming too close to the journal...and it would crack and break.
We now can buy new cranks from DPR crankshafts....so that issue seems to be less troublesome.
Rich
rhodyguy
May 13 2015, 01:07 PM
forget heat. in all likelihood, you need to plan which header and muffler system you intend to run. what's your fuel supply system plan? carbs, dual throat throttle body f.i.? ignition? what's the cylinder budget? it's a whole lot more than just displacement.
jesiv
May 13 2015, 01:14 PM
I am planning carbs. I really want heat. I want the car to be drivable e.g. Drive from San Francisco to Los Angels.
crash914
May 13 2015, 01:50 PM
Best bet is a 2056. Then just driv3 it. Best bang for the $.
nine9three
May 13 2015, 02:26 PM
Not to hijack this thread, but I'm seriously thinking 2270. Seems to be a lot of write-up on this displacement, and it matches what I would like to get in terms of H.P. I'm making an assumption here but the larger the displacement the more critical the components needed to equal reliability.
jesiv
May 13 2015, 02:29 PM
Yeah but looking for more power. It's hard to go from a boxster to the 914. I am keeping the 1.8 for originality. This engine is all about power and fun :-)
r_towle
May 13 2015, 02:53 PM
So a 2.4 with heat exchangers
jesiv
May 13 2015, 03:07 PM
I assume that's what you would do... Other options??
Mueller
May 13 2015, 03:31 PM
Doesn't Tangerine Racing have proper headers with heat?
McMark
May 13 2015, 03:32 PM
What year boxster? For a 2015 Boxster S (2900lbs/315hp) you need around 200hp to match the power/weight in a 914. A 2000 Boxster S (2800lbs/250hp) only needs 180hp for a 2100lbs 914.
200hp from a Type 4 is a hard number to reach. You better have some well designed heads, a cam that's specially designed to take advantage, and and intake and exhaust system that's up to the task. Take all that, and then consider the torque curve of the Boxster motor with VarioCam. You're easily getting into 3.6 transplant territory.
If you need 200+ hp in your car, there are three viable options: 3.6, Subaru, V8. All of which will be a hell of a lot more reliable in the long run.
But all that nay-saying aside, if you want to pursue a Type 4, I wouldn't use the 103 cylinders. I think a stoker with 96mm pistons that's well designed will surpass the additional displacement. The old adage, "There's no replacement for displacement," is basically the shotgun approach the making power. Make everything bigger and you make more power. But for our motors there is a practial limit to how big you can go. So instead of jumping into unreliable parts (103s), use proven 96s and gain power through efficiency.
McMark
QUOTE(Mueller @ May 13 2015, 02:31 PM)
Proper headers, heat
-ish.
rhodyguy
May 14 2015, 09:11 AM
Stock heat exchangers may not support a 2.4. 2056, heat exchangers, stock fi components, or carbs set up correctly for your application. No need for real expensive cylinders. Now you make your cam choise. Do the math. Seriously.
May 14 2015, 09:44 AM
I would do a 3.2 conversion.
76-914
May 14 2015, 10:07 AM
To quote the Cowardly Lion from Oz, "Not no way, not no how!" Take McMark's advice. Especially if you want reliability.
914werke
May 14 2015, 10:24 AM
QUOTE(McMark @ May 13 2015, 02:32 PM)
I Disagree.
I think you are using a shotgun approach with your statement.
How are 103's unreliable? If you are referring to old tech cast iron cyl's then I understand, but a properly prepped case & heads mated with forged pistons & Billet alum. cylinders should be no less reliable (and likely more reliable) than a stock motor.
rhodyguy
May 14 2015, 10:31 AM
Who sells 'forged' aluminum cylinders for a t-4 and at what cost? What are those same cylinders coated with?
r_towle
May 14 2015, 10:42 AM
QUOTE(rhodyguy @ May 14 2015, 12:31 PM)
ln engineering
EMW in California.
Coated the same way /6 aluminum cylinders are coated.
LN makes his own, and they are not cheap.
They are really nice pieces.
EMW sells imported units that I have not heard any bad things about (except from Jake and LN) and I have heard nothing good either....I just know they are available, people buy them and they are cheap.
I suspect one reason people dont come out and talk about using the lower costs units are they may get flamed here and at the end of the day its a hassle .....so they just keep it to themselves.
I have 103mm Cast iron cylinder and forged pistons.
The motor needs new rings about every 10k, but that is OK by me.
rich
914werke
May 14 2015, 11:11 AM
QUOTE(rhodyguy @ May 14 2015, 09:31 AM)
a properly prepped case & heads mated with Forged Pistons & Billet alum. cylinders should be no less reliable (and likely more reliable) than a stock motor.
Corrected. Happy now?
rhodyguy
May 14 2015, 11:14 AM
Happy? Sure, if you are. Are YOU happy? I looked around EMW. I see no "forged"cylinders. Pistons? Yes. Forged cyl? No. The EMW cylinders are $735 a set. Pistons, rings are extra. The required machine work is prob pretty cheap.
Jake Raby
May 14 2015, 12:48 PM
Build it as big as you can afford the headwork to support.
Its easy to build a huge misconfiguration.
toon1
May 14 2015, 12:57 PM
Do a turbo and call it good
r_towle
May 14 2015, 01:07 PM
QUOTE(Jake Raby @ May 14 2015, 02:48 PM)
THAT is some sage advice.
Headwork costs lots....
If you dont have decent heads, I would certainly suggest you buy heads from Jake/LN/Len that are based upon new castings, tested, fully setup, port matched....all of it....
Its THE easiest way to go and probably comparable to building a large set of heads properly...especially the port matching.
crash914
May 14 2015, 01:35 PM
And now you are back in the 12k plus area. 2056 is the best bang for the buck.
914werke
May 14 2015, 01:48 PM
That is also the Rub....
According to past posts by Jake to make 103's burn efficiently you need dual plug.
Ive spoken to Len somewhat recently (well, email..) and he no longer offers Dual plugging on his heads.
Jake Raby
May 14 2015, 01:55 PM
QUOTE(rdauenhauer @ May 14 2015, 11:48 AM)
He's too busy doing them for me :-)
Its hard to beat a 2270...
Mueller
May 14 2015, 04:41 PM
QUOTE(Jake Raby @ May 14 2015, 12:55 PM)
What is that bore/stroke wise?
Kansas 914
May 14 2015, 04:46 PM
QUOTE(Mueller @ May 14 2015, 04:41 PM)
I think it is 78.4 X 96 (stroke/bore)
Kansas 914
Duplicate post
nine9three
May 14 2015, 05:14 PM
Mark Henry
May 15 2015, 11:04 AM
To me once you hit 2270 that is the wall were it's time to seriously think of doing a /6 or a water cooled engine. Although admittedly the /6 will likely be the most expensive solution.
Any bigger bore T4, done right (nickies), quickly starts into /6 money.
If you want heat exchangers it's foolish to waste your money on anything bigger than a 2056 IMHO.
I have a T4 2.6 nickies engine in my bug it's a lot of fun and pooploads of torque, but my kid says it sounds like a diesel truck tractor at WOT.
If I had a do-over i likely would stick to a 2270 in the bug.
My 914 is getting 3.0 /6 (if I ever get it done
) and if I had to pay today's /6 prices I wouldn't do it again.
Jake Raby
May 15 2015, 12:31 PM
2270 was my sweet spot for 1\5 years. Today the 2,432 is my new favorite and it costs the same money since we went to Nickies on all engines as standard.
