Anti abrasion layer between gas tank and firewall |
Rleog |
May 11 2015, 09:02 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
What material do you guys use for this?
May 11 2015, 09:09 AM
I used neoprene. Got it from my local hardware store. Glued two layers together with trim adhesive, then glued them into place on the firewall. Front bulkhead too.
I think the original stuff was felt? Not sure, but it did a pretty decent job of holding water against the tank and firewall. The carpet that some people have used over the years as a replacement did a really good job of holding water. --DD |
type47 |
May 11 2015, 09:19 AM
sean_v8_914 |
May 11 2015, 11:21 AM
old pc of carpet
Rleog |
May 11 2015, 11:58 AM
Thanks for the quick replies.
Keeping away from the hydrophyllic stuff seems a good idea. |
Spoke |
May 11 2015, 01:49 PM
I used furniture pads with adhesive on the back as sold at Home Depot and Lowes. Comes in 4x6 inch sheets.
PanelBilly |
May 11 2015, 02:58 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I used a rubber sheet from the plumbing department
saigon71 |
May 11 2015, 05:43 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Polyethylene pipe wrap from Lowes, glued in with 3M adhesive. Won't hold water.
Brian_Boss |
May 13 2015, 12:45 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
I found some adhesive backed felt at Grainger that is a near perfect match to the stock pads. Item # 2FJA9 . Felt Sheet, F3,1/4 In Thick, 12 x 12 In
Link |
worn |
May 13 2015, 01:37 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
What material do you guys use for this? Closest is probably felt from the insoles of shoes or as add one for shoes. I like the felt. If you are worried you can scotch guard. In my experience the rust on the inside of the tank is wher the worry is. Maybe line the tank with neoprene? Oh, just kidding Dave, I spect you are right on this one too. I saved the old ones spruced them up a bit and reglued them on. Figure the tank holds them in place. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:26 PM |
