Anyone have a speedometer rebuilder they have used? Hoping to find one in the midwest |
rick 918-S |
May 12 2015, 09:59 AM
Hey nice rack! -Celette Group: Members Posts: 20,456 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
crap! I was just quoted 350-450 to go through a 914 speedometer! Wow! It's likely worth it but I would like to at least look for an option.
I have three 150 mph speedometers with failed odometers. |
zambezi |
May 12 2015, 10:51 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
It's usually just the plastic drive gear that has crumbled. I have fixed 928, 944 and a 993 odometers with that problem. Fairly easy to do yourself. I would assume the 914 to be just as easy.
sean_v8_914 |
May 12 2015, 11:13 AM
north hollywood speedo. Helmut is still there but more as a tech advisor
sbsix |
May 12 2015, 11:49 AM
only the lead dog enjoys a change in scenery... Group: Members Posts: 450 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Rick, North Hollywood redid my instruments and did a great job and at a reasonable amount. I had them do some custom touches as well.
naro914 |
May 12 2015, 01:14 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
We've used Nichols Speedometer for years, from back when I owned Exclusive Motors. But it was easy...there are close to us here in Charlotte.
http://www.nsifleet.com/home.html |
jim_hoyland |
May 12 2015, 02:12 PM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
North Hollywood,; (IMG:style_emoticons/default/agree.gif) best around. You can talk to Helmut directly too...
wes |
May 12 2015, 02:45 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I don't know how they compare to Hollywood Speedometer but Palo Alto Speedometer did all my gages and I couldn't be happier!
TheCabinetmaker |
May 12 2015, 03:00 PM
The odo is an easy fix Rick.
RonnieJ |
May 12 2015, 03:05 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I had my odometer repaired in Virginia at Specialty Gauge and a great job and not overly expensive here is the link.
http://www.thesamba.com/vw/classifieds/detail.php?id=1298885 |
andys |
May 12 2015, 03:14 PM
The odo is an easy fix Rick. You can by the odo gear from: http://www.odometergears.com/products/Porsche/914+70-76/75 I did my 993 speedo odo gear myself. Hardest part is un-rolling the surround, then re-rolling it without damage. I'm sure NH Speedo and others have a tool that won't mar the surround. Andys |
Kansas 914 |
May 12 2015, 03:28 PM
The odo is an easy fix Rick. (IMG:style_emoticons/default/agree.gif) I fixed mine with a few drops of Super Glue Gel. |
rick 918-S |
May 13 2015, 08:47 AM
I dug through my stash and found a speedo with a rebuilders tag on it. I tested it and it works. So I decided to look into one of the pother ones I have. Pelican has an article on this. I fixed one last night. I will fix the others also now.
Kansas 914 |
May 13 2015, 09:48 AM
I dug through my stash and found a speedo with a rebuilders tag on it. I tested it and it works. So I decided to look into one of the pother ones I have. Pelican has an article on this. I fixed one last night. I will fix the others also now. (IMG:style_emoticons/default/aktion035.gif) |
May 13 2015, 10:55 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Another source for pretty much anything 914-related in the Midwest would be Brad Mayeur at 914 Limited. If he can't fix it, he'll know of a good place to get it fixed.
But it sounds like you're doing it yourself--which isn't hard, it was my first really involved 914 repair! (IMG:style_emoticons/default/smile.gif) --DD |
DRPHIL914 |
May 13 2015, 11:32 AM
sorry for the highjack, but do any of these companies re-callibrate as well?
mine is off by 5mph at 60mph, shows only55(verified with gps). car once had lower profile 15's and i now have 205/55 16's so my O.D. is about 1" larger than before, and i would likeit if it were closer . i dont plan on running smaller tires on these 16's, i think i found the combo i like. |
rick 918-S |
May 13 2015, 01:31 PM
sorry for the highjack, but do any of these companies re-callibrate as well? mine is off by 5mph at 60mph, shows only55(verified with gps). car once had lower profile 15's and i now have 205/55 16's so my O.D. is about 1" larger than before, and i would likeit if it were closer . i dont plan on running smaller tires on these 16's, i think i found the combo i like. Re-cal was mentioned in my phone conversation. Maybe that's where the $ 450.00 price came in. I'm a 914 guy. I just fixed it. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:36 AM |
