rick 918-S
May 12 2015, 09:59 AM
crap! I was just quoted 350-450 to go through a 914 speedometer! Wow! It's likely worth it but I would like to at least look for an option.
I have three 150 mph speedometers with failed odometers.
zambezi
May 12 2015, 10:51 AM
It's usually just the plastic drive gear that has crumbled. I have fixed 928, 944 and a 993 odometers with that problem. Fairly easy to do yourself. I would assume the 914 to be just as easy.
sean_v8_914
May 12 2015, 11:13 AM
north hollywood speedo. Helmut is still there but more as a tech advisor
sbsix
May 12 2015, 11:49 AM
Rick, North Hollywood redid my instruments and did a great job and at a reasonable amount. I had them do some custom touches as well.
naro914
May 12 2015, 01:14 PM
We've used Nichols Speedometer for years, from back when I owned Exclusive Motors. But it was easy...there are close to us here in Charlotte.
http://www.nsifleet.com/home.html
jim_hoyland
May 12 2015, 02:12 PM
North Hollywood,;
best around. You can talk to Helmut directly too...
wes
May 12 2015, 02:45 PM
I don't know how they compare to Hollywood Speedometer but Palo Alto Speedometer did all my gages and I couldn't be happier!
TheCabinetmaker
May 12 2015, 03:00 PM
The odo is an easy fix Rick.
RonnieJ
May 12 2015, 03:05 PM
I had my odometer repaired in Virginia at Specialty Gauge and a great job and not overly expensive here is the link.
http://www.thesamba.com/vw/classifieds/detail.php?id=1298885
andys
May 12 2015, 03:14 PM
QUOTE(The Cabinetmaker @ May 12 2015, 02:00 PM)
You can by the odo gear from:
http://www.odometergears.com/products/Porsche/914+70-76/75I did my 993 speedo odo gear myself. Hardest part is un-rolling the surround, then re-rolling it without damage. I'm sure NH Speedo and others have a tool that won't mar the surround.
Andys
Kansas 914
May 12 2015, 03:28 PM
QUOTE(The Cabinetmaker @ May 12 2015, 03:00 PM)
I fixed mine with a few drops of Super Glue Gel.
rick 918-S
May 13 2015, 08:47 AM
I dug through my stash and found a speedo with a rebuilders tag on it. I tested it and it works. So I decided to look into one of the pother ones I have. Pelican has an article on this. I fixed one last night. I will fix the others also now.
Kansas 914
May 13 2015, 09:48 AM
QUOTE(rick 918-S @ May 13 2015, 08:47 AM)
Dave_Darling
May 13 2015, 10:55 AM
Another source for pretty much anything 914-related in the Midwest would be Brad Mayeur at 914 Limited. If he can't fix it, he'll know of a good place to get it fixed.
But it sounds like you're doing it yourself--which isn't hard, it was my first really involved 914 repair!
--DD
DRPHIL914
May 13 2015, 11:32 AM
sorry for the highjack, but do any of these companies re-callibrate as well?
mine is off by 5mph at 60mph, shows only55(verified with gps). car once had lower profile 15's and i now have 205/55 16's so my O.D. is about 1" larger than before, and i would likeit if it were closer . i dont plan on running smaller tires on these 16's, i think i found the combo i like.
rick 918-S
May 13 2015, 01:31 PM
QUOTE(Philip W. @ May 13 2015, 12:32 PM)
Re-cal was mentioned in my phone conversation. Maybe that's where the $ 450.00 price came in. I'm a 914 guy. I just fixed it.
