FS: Weber 40 IDTP Carbs |
casey944 |
May 13 2015, 11:48 AM
Member Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
For sale is a set of weber 40 IDTP Carbs that I purchased a few months ago. I am selling as my project has stalled and I want to allocate money elsewhere. Once receiving the carbs I went through them and realized that they, like a lot others, needed help. The floats were crushed and they needed a thorough cleaning. Asking 1900 Shipped in the US + Paypal fees.
One of the air correction shoulders ports was cracked. I sent the body to Paul @ Performance oriented. He corrected the cracked port and did the following: Weber service Master rebuild kit Clean(ultra sonic), re-bush throttle body (using Teflon bearings) and bench flow throttle valves to be re-used Supply two, new Weber floats, brass Supply (4) fuel screens for banjo bolts Supply two main body stud Zinc plate intake air horns I also purchased the correct jets(which are included/installed) for my 2.2T at sea level: 30mm main venturis 130 mains F26 emulsion tubes 170 air corrections 55 idles These came with the carbs, would need to be cleaned thoroughly for reuse: Idle-52 Imul - F1 Main Air - 185(definitely need to replace as they are pretty buggered up) Vent - 27 Following all of this work being done I assembled one of the carbs. I am an amateur, i recommend you take it down and reassemble to your liking. I also recommend you inspect and possibly replace the nozzles for the accel pumps. You get everything shown in these photos: (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539291.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539291.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539292.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539292.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539293.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539293.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539294.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539294.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539294.9.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539295.10.jpg) |
casey944 |
More Photos:
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539323.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539323.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539324.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10654-1431539324.4.jpg) |
Lo-Fi Version | Time is now: 28th May 2024 - 11:52 PM |
