WTB 2.4L or 3.0 complete motor, 2.4 L six cyl. or 3.0L older rebuild ok. |
Dion |
May 14 2015, 02:49 PM
RN Group: Members Posts: 2,765 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hi guys,
Going to the dark side. I've decided I want a six. Would like to purchase a good condition 2.4L six or 3.0 Could be from 911 E,T or SC Just putting feelers out here. Would prefer complete motor with carbs. But a nice running Fuel inj. wouldn't be excluded. I know prices are all over the map. So I don't have a set price. It obviously depends on motor/situation. I live in PA. Please pm me with any info. I would be keeping the 901 trans. as it has been recently overhauled. Thanks everyone. Cheers,Dion |
type47 |
May 14 2015, 03:46 PM
Wha!!!! Taking out that nice running CIS motor? I'm moving in that direction too. If interested, check out my blog: type 47's blog. The 69 T engine (2L) is completely disassembled and the case is in for measurement. Do you want to build a motor?
koozy |
May 14 2015, 04:36 PM
Senior Member Group: Members Posts: 648 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
What is your budget?
Dion |
May 14 2015, 06:31 PM
What is your budget? Ahhhh. Yeah still working those numbers to see where I'm going to be at. I know the $ will be up as the more and fresh the motor will be. Heheh yes Jim, Dave is a bad influence. But I'm trying ( in my mind) to capture that rally car vibe of the 70's with a strong 2.4L for long distance runs and rallies. |
May 14 2015, 06:53 PM
Budget for -
Engine Engine tin Headers or heat exchangers Muffler Engine wire harness Oil lines Oil tank Oil cooler Engine mount Modify shift linkage Tach Oil pressure/temp gauge Maybe a starter motor Accelerator linkage Miscellaneous nuts and bolts clutch (IMG:style_emoticons/default/smile.gif) |
Dion |
May 14 2015, 06:55 PM
Mark, were you in my garage? That's my list! Heheh
koozy |
May 15 2015, 07:46 AM
Don't forget springs, shock valving, chassis stiffening and tires.
MJHanna |
May 15 2015, 09:33 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
I’ve got one but you would not like the price, 2.4 alum case, pauter rods, 964 oil pump, head work, twin plugged, blah blah bah.
What springs are recommended when you go to a six? |
koozy |
May 15 2015, 10:32 PM
For a street car I'd start with 19mm torsion bars and 200 pound rear springs. Adjustable front anti-roll bar to tune.
Dion |
May 17 2015, 10:15 PM
koozy |
May 17 2015, 10:25 PM
Hhmmm. I'm interested in knowing why you skipped over the 2.7?
x-faktory |
May 17 2015, 11:11 PM
Newbie Group: Members Posts: 21 Joined: 16-August 13 From: PNW Member No.: 16,261 Region Association: Pacific Northwest |
http://www.ebay.com/itm/Porsche-911-2-7-en...me=STRK:MESE:IT
yea...............don't pass over the 2.7....maybe the most perfect 914/6 engine ever. I may be biased regards, al |
type47 |
May 18 2015, 06:12 AM
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/pray.gif) That would be a great solution to your get-a-6 itch ... |
koozy |
May 18 2015, 08:41 AM
Yep, that is a nice mild build. Should go for over $20K, I would think.
billh1963 |
May 18 2015, 09:24 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Yep, that is a nice mild build. Should go for over $20K, I would think. (IMG:style_emoticons/default/blink.gif) |
Dion |
May 18 2015, 10:22 AM
Yep, that is a nice mild build. Should go for over $20K, I would think. (IMG:style_emoticons/default/blink.gif) I would not mind a 2.7 but I'm thinking the price will really be out of my scope. They are commanding a premium right now. If I add all the parts to make a nice 2.7 starting with basic case and add the necessary bits, well... I've seen a nice completed one for 25K. I still need other bits. |
Larmo63 |
May 18 2015, 12:14 PM
Can I sell a kidney to buy that mill?
76-914 |
May 18 2015, 04:12 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Budget for - Engine Engine tin Headers or heat exchangers Muffler Engine wire harness Oil lines Oil tank Oil cooler Engine mount Modify shift linkage Tach Oil pressure/temp gauge Maybe a starter motor Accelerator linkage Miscellaneous nuts and bolts clutch (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) Except for the Engine Tin,Oil Tank and Oil Lines, that description fits a Suby conversion as well. |
x-faktory |
May 18 2015, 07:23 PM
koozy |
May 18 2015, 09:20 PM
Al, are you doing EFI kits? Please PM me with your email. I would love to chat with you about that
Lo-Fi Version | Time is now: 14th May 2024 - 11:27 PM |
