Dion
May 14 2015, 02:49 PM
Hi guys,
Going to the dark side. I've decided I want a six.
Would like to purchase a good condition 2.4L six or 3.0
Could be from 911 E,T or SC
Just putting feelers out here. Would prefer complete motor with
carbs. But a nice running Fuel inj. wouldn't be excluded. I know prices are all over
the map. So I don't have a set price. It obviously depends on motor/situation.
I live in PA. Please pm me with any info.
I would be keeping the 901 trans. as it has been
recently overhauled. Thanks everyone.
Cheers,Dion
type47
May 14 2015, 03:46 PM
Wha!!!! Taking out that nice running CIS motor? I'm moving in that direction too. If interested, check out my blog: type 47's blog. The 69 T engine (2L) is completely disassembled and the case is in for measurement. Do you want to build a motor?
koozy
May 14 2015, 04:36 PM
What is your budget?
Dion
May 14 2015, 06:31 PM
QUOTE(koozy @ May 14 2015, 02:36 PM)
Ahhhh. Yeah still working those numbers to see where I'm going to be at. I know the
$ will be up as the more and fresh the motor will be.
Heheh yes Jim, Dave is a bad influence.
But I'm trying ( in my mind) to capture that
rally car vibe of the 70's with a strong 2.4L for long distance runs and rallies.
May 14 2015, 06:53 PM
Budget for -
Engine
Engine tin
Headers or heat exchangers
Muffler
Engine wire harness
Oil lines
Oil tank
Oil cooler
Engine mount
Modify shift linkage
Tach
Oil pressure/temp gauge
Maybe a starter motor
Accelerator linkage
Miscellaneous nuts and bolts
clutch
Dion
May 14 2015, 06:55 PM
Mark, were you in my garage? That's my list! Heheh
koozy
May 15 2015, 07:46 AM
Don't forget springs, shock valving, chassis stiffening and tires.
MJHanna
May 15 2015, 09:33 AM
I’ve got one but you would not like the price, 2.4 alum case, pauter rods, 964 oil pump, head work, twin plugged, blah blah bah.
What springs are recommended when you go to a six?
koozy
May 15 2015, 10:32 PM
For a street car I'd start with 19mm torsion bars and 200 pound rear springs. Adjustable front anti-roll bar to tune.
Dion
May 17 2015, 10:15 PM
QUOTE(koozy @ May 15 2015, 05:46 AM)
Rear suspension done. Stiffening in the cards
I did an edit. A 2.4L or 3.0L is the candidates now.
Thanks everyone.
Cheers,Dion
koozy
May 17 2015, 10:25 PM
Hhmmm. I'm interested in knowing why you skipped over the 2.7?
x-faktory
May 17 2015, 11:11 PM
http://www.ebay.com/itm/Porsche-911-2-7-en...me=STRK:MESE:ITyea...............don't pass over the 2.7....maybe the most perfect 914/6 engine ever.
I may be biased
regards,
al
type47
May 18 2015, 06:12 AM
QUOTE(x-faktory @ May 17 2015, 09:11 PM)
That would be a great solution to your get-a-6 itch ...
koozy
May 18 2015, 08:41 AM
Yep, that is a nice mild build. Should go for over $20K, I would think.
billh1963
May 18 2015, 09:24 AM
QUOTE(koozy @ May 18 2015, 10:41 AM)
Dion
May 18 2015, 10:22 AM
QUOTE(billh1963 @ May 18 2015, 07:24 AM)
I would not mind a 2.7 but I'm thinking the price will really be out of my scope.
They are commanding a premium right now.
If I add all the parts to make a nice 2.7 starting with basic case and add the necessary bits, well... I've seen a nice completed one for 25K. I still need other bits.
Larmo63
May 18 2015, 12:14 PM
Can I sell a kidney to buy that mill?
76-914
May 18 2015, 04:12 PM
QUOTE(mepstein @ May 14 2015, 05:53 PM)
Budget for -
Engine
Engine tin
Muffler
Engine wire harness
Oil lines
Oil tank
Oil cooler
Engine mount
Tach
Accelerator linkage
clutch
Except for the Engine Tin,Oil Tank and Oil Lines, that description fits a Suby conversion as well.
x-faktory
May 18 2015, 07:23 PM
QUOTE(koozy @ May 18 2015, 07:41 AM)
My reserve is quite a bit lower than that......................bid early and often, you never know.....you might get lucky!!!!
regards,
al
koozy
May 18 2015, 09:20 PM
Al, are you doing EFI kits? Please PM me with your email. I would love to chat with you about that
