Case studs for cylinders/heads, Where to get them? |
Hine62 |
May 16 2015, 06:10 AM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I'm building a 2258 and need to replace the case studs. Where is the best place to get them?
hine62 |
May 16 2015, 07:41 AM
LN Engineering
Hine62 |
May 16 2015, 09:50 AM
Any where else?
Mueller |
May 16 2015, 10:08 AM
Any where else? I was looking at these...not sure if they sell directly or not. (I see an order toll free number) http://raceware-fasteners.com/head-stud-kits/ 911 engine and Type IV stuff. |
Hine62 |
May 16 2015, 10:26 AM
I saw those too, thanks for the replies.
hine62 |
Jake Raby |
May 16 2015, 11:43 AM
Nothing but problems with raceway in the past...
What happened to your stock studs? I prefer stock studs up to 12:1 CR when using iron cylinders, with a 96mm bore |
Hine62 |
May 16 2015, 12:09 PM
Stock studs were so rusted that I had to cut one. Unfortunately...
02loftsmoor |
May 16 2015, 12:14 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
Nothing but problems with raceway in the past... What happened to your stock studs? I prefer stock studs up to 12:1 CR when using iron cylinders, with a 96mm bore I want replace mine because of age and I like case savers/ inserts installed in the case. I guess you would need the head studs to stretch a bit because of the cylinders growing because of the heat. I been watching your writings on zero valve lash when cold.. Wes |
StratPlayer |
May 16 2015, 12:19 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Try http://www.highperformancehouse.com/, he might be able to help you out.
May 16 2015, 03:41 PM
Curious, have you tried the dealer?
TheCabinetmaker |
May 16 2015, 03:59 PM
Do they have to be new? I've lots of used ones. Be happy to send you a few.
Hine62 |
May 16 2015, 04:44 PM
I don't know? That is a great question. I think because the crank will be 78mm from 66mm that the studs may need to be longer. I'm not sure...
Hine62 |
May 16 2015, 04:48 PM
May 16 2015, 05:22 PM
Studs are the same length unless you get custom long cylinders.
The pin height on the piston changes to make up the difference in the stroke. Rich |
Jake Raby |
May 17 2015, 02:39 PM
If you use the proper combination of components your 78mm stroke engine can be the same or even more narrow than a stock engine!
Harpo |
May 17 2015, 04:03 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I was told that Racewear is very good but a step down from ARP
Hine62 |
May 17 2015, 08:37 PM
Mark Henry |
May 19 2015, 05:33 AM
Waste of money unless you are using nickies, just get a good used set.
IMO the stock through bolts are nicer than ARP, even though I have ARP on my 2.6 nickies engine. |
0396 |
May 19 2015, 07:54 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
johnhora |
May 19 2015, 09:47 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Hine62...I have some used case thru bolts if needed....
Lo-Fi Version | Time is now: 14th May 2024 - 08:01 AM |
