What is the best way to fix broken clutch tube, I have seen articals about this but can't find them |
ventedrib |
May 16 2015, 01:08 PM
Member Group: Members Posts: 104 Joined: 10-August 08 From: Monroe La. Member No.: 9,406 Region Association: South East States |
I have a 72 with a broken clutch tube. It appears to be broke in the front it looks fine at the firewall any help would be mutch appreciated.
pilothyer |
May 16 2015, 01:30 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Look at the attached picture........determine where you will need to cut an access hole in the tunnel (cut 3 sides of a "square" and fold up and out of the way. reweld the tube in place.......be very careful, there are fuel lines in there close by. After you have reattached the clutch tube bend the flap back over and reweld.......the clutch tube is the large one that goes furthermost toward the front of the tunnel. I have seen this problem repaired using the "no weld" method by using a screw down clamp over the loose tube, but requires a screw thru the floor....just not right IMO.
ventedrib |
May 16 2015, 01:41 PM
Look at the attached picture........determine where you will need to cut an access hole in the tunnel (cut 3 sides of a "square" and fold up and out of the way. reweld the tube in place.......be very careful, there are fuel lines in there close by. Thanks it looks like mine may have broke on that middle weld, will have to get a light and a mirror to be sure, but that pic really helps thanks. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:19 PM |
