What is the best way to fix broken clutch tube, I have seen articals about this but can't find them |
ventedrib |
May 16 2015, 01:08 PM
Member Group: Members Posts: 104 Joined: 10-August 08 From: Monroe La. Member No.: 9,406 Region Association: South East States |
I have a 72 with a broken clutch tube. It appears to be broke in the front it looks fine at the firewall any help would be mutch appreciated.
sean_v8_914 |
May 19 2015, 11:28 AM
i've done at least 20 that i can remember. just rebuilt my computer so i dont have my data transfered yet but when i do, ill do a write up with photos.
the easy way out is more work and complications later so resist that temptation. once the firewall rips, all 3 attachment points require correction. the tube has migrated and also needs to be in the right position prior to any welding i go in thru the belly to fix the center bracket because it hangs from teh roof of the tunnel as seen in pylothyer's photo the non welded clamp will work fine untill your on the 405 at 5pm on a friday in the #3 lane with a cement trunk behind you. ps. please dont braze it |
McMark |
May 19 2015, 11:30 AM
ps. please dont braze it But brazing is the correction solution -- if it's done right. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:59 PM |
