What is the best way to fix broken clutch tube, I have seen articals about this but can't find them |
ventedrib |
May 16 2015, 01:08 PM
Member Group: Members Posts: 104 Joined: 10-August 08 From: Monroe La. Member No.: 9,406 Region Association: South East States |
I have a 72 with a broken clutch tube. It appears to be broke in the front it looks fine at the firewall any help would be mutch appreciated.
sean_v8_914 |
May 19 2015, 11:28 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
i've done at least 20 that i can remember. just rebuilt my computer so i dont have my data transfered yet but when i do, ill do a write up with photos.
the easy way out is more work and complications later so resist that temptation. once the firewall rips, all 3 attachment points require correction. the tube has migrated and also needs to be in the right position prior to any welding i go in thru the belly to fix the center bracket because it hangs from teh roof of the tunnel as seen in pylothyer's photo the non welded clamp will work fine untill your on the 405 at 5pm on a friday in the #3 lane with a cement trunk behind you. ps. please dont braze it |
KELTY360 |
May 20 2015, 05:15 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
once the firewall rips, all 3 attachment points require correction. the tube has migrated and also needs to be in the right position prior to any welding i go in thru the belly to fix the center bracket because it hangs from teh roof of the tunnel as seen in pylothyer's photo I'm faced with the same thing, although the firewall has ripped in my case. What are the three attachment points? When you say you go in thru the belly, does that mean you cut the pan from underneath? |
Lo-Fi Version | Time is now: 17th May 2024 - 08:37 PM |
