74 2.0 F.I. NO spark, Ran before new battery |
Nemisus |
May 17 2015, 02:14 PM
Member Group: Members Posts: 82 Joined: 1-October 11 From: North Bay CA Member No.: 13,631 Region Association: Northern California |
So I am stumped. When I took delivery of my newly acquired 74 914 the car would start up just fine with a jump box.
I went out and bought a new battery and now I have no spark... at lest from I can tell doing the simple spark tests I have done. I just did an Ohms test on my Ignition coil and here is what I got Primary: 1.4 Secondary: 10.41 Per the Pelican Technical Article I should see readings like this: primary coil winding's should give a reading of 0.3-0.6 ohms. Secondary coils should be near 600 ohms. If I understand my results I am significantly higher than where I should be? But does that mean my coil is is the cause of no spark. The only thing I changed was a busted fuel line and put in a new battery... Now the car will not start. Any ideas on where else to look? Thanks in advance Cheers Nem |
Nemisus |
May 24 2015, 10:39 AM
Dave,
That is disappointing news as these plugs came in a kit. I suppose this just happens. Any suggestions on a good plug? The NGK's are working, but certainly could stand to be replaced. Now that I know the 2.0 runs... and fairly well give the time it sat. I want to refresh the ignition system and fuel system. Are there any places that offer upgrades? appreciate the feedback. Cheers Nemi |
Lo-Fi Version | Time is now: 24th May 2024 - 11:24 AM |
