74 2.0 F.I. NO spark, Ran before new battery |
Nemisus |
May 17 2015, 02:14 PM
Member Group: Members Posts: 82 Joined: 1-October 11 From: North Bay CA Member No.: 13,631 Region Association: Northern California |
So I am stumped. When I took delivery of my newly acquired 74 914 the car would start up just fine with a jump box.
I went out and bought a new battery and now I have no spark... at lest from I can tell doing the simple spark tests I have done. I just did an Ohms test on my Ignition coil and here is what I got Primary: 1.4 Secondary: 10.41 Per the Pelican Technical Article I should see readings like this: primary coil winding's should give a reading of 0.3-0.6 ohms. Secondary coils should be near 600 ohms. If I understand my results I am significantly higher than where I should be? But does that mean my coil is is the cause of no spark. The only thing I changed was a busted fuel line and put in a new battery... Now the car will not start. Any ideas on where else to look? Thanks in advance Cheers Nem |
TheCabinetmaker |
May 24 2015, 02:19 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The cap'n will also tell you (and I agree), if you go to pertronics carry a set of old technology points and condenser and the tools to change them with on the side of the road. I changed to a pertronics way back when they were new technology. They left me stranded on the side of the road. I can install 10 sets of points for the price of the pertronics. I'm not saying that one is better than the other, just arming you with all the facts so you can make an informed decision.
Lo-Fi Version | Time is now: 18th May 2024 - 08:12 AM |
