74 2.0 F.I. NO spark, Ran before new battery |
Nemisus |
May 24 2015, 03:41 PM
Member Group: Members Posts: 82 Joined: 1-October 11 From: North Bay CA Member No.: 13,631 Region Association: Northern California |
Ive been reading a bit about this.
Seems some have had failures and others have not. I'd say that is possible with anything. I just learned that I was only running on 3 cylinders. I discovered I had a clogged injector from the line side. Replaced the short lines and cleaned up what I could and now the 2.0 is running pretty well. All that aside this car will not be seeing the road anytime soon. I'm learning the entire floor board will need to be changed... If I'm going to get this restoration going I might as well get it ready for the hard stuff. Not that I imagine there is any other way... I was just hoping for something I could drive and fix as I went! I am a bit discouraged as I do not have the resources to get started. I can weld and am pretty mechanically inclined so I have full confidence I can do this. Just need some specialty tools to get it going. The biggest challenge is a finding a Rotisserie. I'm thrilled to death that I have a team of knowledgeable 914 enthusiasts to lead my way right here at 914world. I am only 34 so I have plenty of youth to get this car new again. I look forward to the challenges as well as the rewards when I am finished. Sorry this was winded... but I had to start somewhere. Thanks for all your info as recommendations. Cheers and stay tuned for some rusty pictures. Nemi |
May 24 2015, 04:44 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
BOSCH W7CC for carbs (then adjust heat range based on particular engine). Also for D-jet. QUOTE Reputable local 914 racer says you can use the Bosch 4 prong plugs #4417 but I havent tried them yet. As far as I can tell, those are the same crappy platinum plugs with three extra electrodes welded on. Still crap IMHO. The cheap Bosch Platinum plugs that you can get everywhere are pretty lousy. There are some very expensive ones that are hard to find that have a solid platinum electrode, as opposed to the little speck the cheapies have. --DD |
Nemisus |
May 24 2015, 08:36 PM
FYI,
The plugs that that came with the tune up kit are BOSCH W7CC. For what its worth |
StarBear |
Nov 11 2018, 09:01 AM
Senior Member Group: Members Posts: 1,858 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Lo-Fi Version | Time is now: 5th May 2024 - 02:07 AM |
