rear suspension |
rear suspension |
fduval |
May 17 2015, 06:48 PM
Newbie Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
Hi , I just changed my rear shocks today , put in new sport bilstein witn 140 lbs springs,
my rear end is about 3/4 inch lower on the right side versus the left side, . is there an adjustment screw that I can play with to get proper level on both sides ? I am new to 914`s !!!!!!!!!!!!!! thanks |
May 17 2015, 07:27 PM
have you driven the car yet? Driving it will settle the shocks. After that, I got nothing.
(IMG:style_emoticons/default/welcome.png) |
fduval |
May 17 2015, 07:28 PM
bulitt |
May 17 2015, 08:23 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Sounds like the spring is not seated in the perch.
fduval |
May 17 2015, 08:35 PM
toon1 |
May 17 2015, 08:41 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
IIRC, bilsteins have adjustable perch locations, maybe they're different.
May 17 2015, 08:48 PM
At least some of the Bilstein shocks have a circlip around the shock body that the lower spring perch rides on. If the spring is in the perch, double-check the position of the circlip. You may need to slide the lower perch upward to see the clip.
--DD |
May 17 2015, 09:26 PM
Driving it will make a difference. Also, might measure out differently with some weight in the driver seat.
fduval |
May 19 2015, 06:07 AM
May 19 2015, 06:11 AM
Driving it will make a difference. Also, might measure out differently with some weight in the driver seat. went for a short drive, the diff now is 1/4 inch side to side . I guess its acceptable. Thanks for all the inputs . as he shocks continue to settle in it will probbable end up very close. (IMG:style_emoticons/default/driving.gif) |
DRPHIL914 |
May 19 2015, 08:49 AM
Driving it will make a difference. Also, might measure out differently with some weight in the driver seat. went for a short drive, the diff now is 1/4 inch side to side . I guess its acceptable. Thanks for all the inputs . as he shocks continue to settle in it will probbable end up very close. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) I have been running these shocks since i bought my car 6 years ago, so i have a question: why the 140# springs? i have found that the 100# springs with the stiffness of the sport bilistiens to be sufficient with street and some sport driving -- just wondering how much of a difference there is? |
pdlightning |
May 25 2015, 11:17 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
Driving it will make a difference. Also, might measure out differently with some weight in the driver seat. went for a short drive, the diff now is 1/4 inch side to side . I guess its acceptable. Thanks for all the inputs . as he shocks continue to settle in it will probbable end up very close. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) I have been running these shocks since i bought my car 6 years ago, so i have a question: why the 140# springs? i have found that the 100# springs with the stiffness of the sport bilistiens to be sufficient with street and some sport driving -- just wondering how much of a difference there is? A lot of people have gone with 180 and 200 springs. I wonder if they had sport Bilsteins? |
Paragon |
May 26 2015, 08:19 PM
Newbie Group: Members Posts: 49 Joined: 6-February 03 From: Corpus Christi, Texas Member No.: 255 Region Association: Southwest Region |
Where on the car are you measuring the ride height? If you're using the fender lip that's not always best..particularly if the car has ever been hit.
Eric_Shea |
May 26 2015, 08:57 PM
140's are perfect with a 19mm adjustable bar up front.
ConeDodger |
May 26 2015, 10:40 PM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Driving it will make a difference. Also, might measure out differently with some weight in the driver seat. went for a short drive, the diff now is 1/4 inch side to side . I guess its acceptable. Thanks for all the inputs . as he shocks continue to settle in it will probbable end up very close. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) I have been running these shocks since i bought my car 6 years ago, so i have a question: why the 140# springs? i have found that the 100# springs with the stiffness of the sport bilistiens to be sufficient with street and some sport driving -- just wondering how much of a difference there is? Ummm... 40# Phillip. (IMG:style_emoticons/default/blink.gif) Seriously, The shocks and springs do a different job. Mine are 200# springs and I use that to deal with the heavier weight of the 3.2 liter Carrera motor. My shocks are Koni adjustables set to full. While this might sound like I have a harsh ride, I don't. The Elephant bushings allow everything to do its job. The springs to bounce the car up and down, the shocks to keep things from bouncing up and down too much. I do use a rear stock sway bar to balance out the much larger Tarret front bar. |
fduval |
May 27 2015, 12:20 PM
Driving it will make a difference. Also, might measure out differently with some weight in the driver seat. went for a short drive, the diff now is 1/4 inch side to side . I guess its acceptable. Thanks for all the inputs . as he shocks continue to settle in it will probbable end up very close. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) I have been running these shocks since i bought my car 6 years ago, so i have a question: why the 140# springs? i have found that the 100# springs with the stiffness of the sport bilistiens to be sufficient with street and some sport driving -- just wondering how much of a difference there is? Ummm... 40# Phillip. (IMG:style_emoticons/default/blink.gif) Seriously, The shocks and springs do a different job. Mine are 200# springs and I use that to deal with the heavier weight of the 3.2 liter Carrera motor. My shocks are Koni adjustables set to full. While this might sound like I have a harsh ride, I don't. The Elephant bushings allow everything to do its job. The springs to bounce the car up and down, the shocks to keep things from bouncing up and down too much. I do use a rear stock sway bar to balance out the much larger Tarret front bar. Yep the car now seats even on both sides, ride is a bit stiffer than when I ran stock but still smooth, not aggressive. at all. But I wonder if I should go with 180 pnds if I drop a 2.7 1974 flat 6 in it ....? |
May 27 2015, 12:33 PM
I think springs and suspension setups are also location dependent. After our winter, east coast roads are terrible. Probably a lot rougher ride compared to Southern California.
Lo-Fi Version | Time is now: 16th May 2024 - 02:39 AM |
