Making a broach?, mike??? Need some advice |
May 17 2015, 08:49 PM
So,
I want to make a spacer for my steering wheel on the 911 to bring it closer to me. There is a very hard to find, and honestly ugly, factory spacer that people are getting big money for now. So, I figure if I can find a way to make a broach that would match the splines on the steering shaft, I would make my own. Is this a common item that all shops have, or can I find a shop that does? I am not looking to replace my wheel with a non stock wheel, just want the spacer. |
screenguy914 |
May 17 2015, 10:20 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
I suppose sliding the seat closer has been tried?
If that didn't work, your objective might be better achieved by purchasing an aftermarket wheel (Momo, Sparco, Nardi, etc.) with the desired dish. The adapter might add some desired depth as well. To move it even closer to you, try stacking multiple adapter plates, the type that adapts the mount hole spacing of different steering wheels (e.g. Momo>Nardi+Nardi>Momo. About 1/4" thick each. See Ebay. Note: I haven't confirmed this yet; just a quicky brain fart. There are probably simpler methods I've overlooked. Sherwood |
May 17 2015, 10:59 PM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've made a couple. Not cheap but not ugly. Works just like stock and will work on 914 or 911 wheels. Stock rivets must be drilled out and then spacer can be fitted and bolted together. Early 914 horn plunger replaces 911 piece.
bulitt |
May 18 2015, 03:41 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Wonder if you could use an old steering column shaft as a broach?
Should work on aluminum spacer? Taper it on a lathe Turn/cut grooves for chip relief Harden it by heat and quench. |
mskala |
May 18 2015, 05:54 AM
I have limited knowledge of machining but splines like that can be done. Grinding
a tool to shape would be pretty simple, but it will be time consuming to set up and do them all. Wouldn't a simpler solution be to get another steering column shaft and lengthen it, then drop in a plain spacer? |
mbseto |
May 18 2015, 06:50 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
For a spacer, does it need to be splined, or can the hole just be cut oversize? If it does need to be locked in, can it be cut with just, say 4 splines? That would be easier to make if it does not have to hold a torque.
Matt Romanowski |
May 18 2015, 07:15 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
There is nothing easy about making good splines with a broach. You're best bet is to find a wire EDM and have them cut it.
wndsnd |
May 18 2015, 08:42 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I have limited knowledge of machining but splines like that can be done. Grinding a tool to shape would be pretty simple, but it will be time consuming to set up and do them all. Wouldn't a simpler solution be to get another steering column shaft and lengthen it, then drop in a plain spacer? This seems like a good solution. Call the guys in Claremont, they probably have one inexpensive in stock. Keep the original in for when you sell the car. |
May 18 2015, 08:59 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
When we were faced with that same problem on my wife's SC, we picked up a 3.2 Carrera wheel from a friend whose daughter had wrecked his car. (Don't feel bad; he had at least two other 911s at the time.) I think the wheel may have been an optional one, but it moved the rim back several inches from the dashboard, which was what we wanted.
Now she doesn't break fingernails when trying to hit apexes on the track. (IMG:style_emoticons/default/smile.gif) --DD |
sixnotfour |
May 18 2015, 10:06 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
May 18 2015, 10:17 AM
Good find. It's an evening project. |
May 18 2015, 11:10 AM
admit I have not looked.
Isnt it held in by one big nut and the hub is splined? If so, I cant use a piece like that above? Or, is the idea to remove the hub from the wheel, and bolt this space, and the hub all together? Sliding the seat forward....good joke. Long legs dont allow that to work...so when you push the seat back, the wheel is now too far away for a comfy long drive. Rich |
Lo-Fi Version | Time is now: 14th May 2024 - 02:54 AM |
