Inexpensive side shift firewall bushing solution |
Harpo |
May 19 2015, 04:20 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Chris design if far superior, more robust and simplier
David |
Bill's Racing 914 |
Jun 7 2015, 12:11 PM
Member Group: Members Posts: 61 Joined: 2-March 14 From: Southern California Member No.: 17,064 Region Association: None |
Here's some more info from a new post: http://www.914world.com/bbs2/index.php?showtopic=257289
Looks like Patrick racing has a solution too. Might be worth a try also. Look at the bottom of the post about his shift rod and the firewall bushings. They take 3/4in dia shift rods. The only problem is the bolt flanges on these bushings may run into the lip around the firewall hole on the early tail shift chassis. Here's the one Patrick uses from Speedway motors: http://www.speedwaymotors.com/Firewall-Mou...-Size,6845.html An alternate bushing from Speedway would be: http://www.speedwaymotors.com/Firewall-Mou...-Size,6845.html Attached image(s) |
ChrisFoley |
Jun 7 2015, 03:03 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The Patrick tunnel rod has a straight drilled hole where the cone screw goes. (IMG:style_emoticons/default/screwy.gif) Just one of many things I don't like about their shift linkage products. |
Bill's Racing 914 |
Jun 7 2015, 07:32 PM
The Patrick tunnel rod has a straight drilled hole where the cone screw goes. (IMG:style_emoticons/default/screwy.gif) Just one of many things I don't like about their shift linkage products. But does that mean the $13 spherical bearing from Speedway with the two hole flange won't work? |
ChrisFoley |
Jun 8 2015, 07:05 AM
BeatNavy |
Jun 8 2015, 07:11 AM
(IMG:style_emoticons/default/agree.gif) (I've read Heinlein!)
Chris provides excellent support for his solutions, too. |
worn |
Jun 8 2015, 08:26 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The Patrick tunnel rod has a straight drilled hole where the cone screw goes. (IMG:style_emoticons/default/screwy.gif) Just one of many things I don't like about their shift linkage products. But does that mean the $13 spherical bearing from Speedway with the two hole flange won't work? I would buy from Chris anytime. Except I want to do it myself (Young Frankenstein). I had a '72 and am adding the side shift. So for $8 I did nothing at all to the new shift tube, but I did alter the bearing for lightness and fit - it was 3/4 inch originally. Easy to put the bearing in the lathe and ream it out. Now if I can finish welding the oil tank for the side and get the motor lifted into place I can try it for real! (IMG:style_emoticons/default/laugh.gif) |
Steve |
Jun 8 2015, 09:56 AM
914 Guru Group: Members Posts: 5,599 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The Patrick tunnel rod has a straight drilled hole where the cone screw goes. (IMG:style_emoticons/default/screwy.gif) Just one of many things I don't like about their shift linkage products. But does that mean the $13 spherical bearing from Speedway with the two hole flange won't work? That's my ad in the classified. First off, I would recommend Chris's solution first. Years ago before Chris offered these products there was a German guy in southern cal, that worked at a machine shop. He recommended the 3 bolt bearing and was shaving down the stock 73 and later shift rods to 3/4" with a lathe to support the bearing. The solution worked great, but as Chris mentions you have to remove the bearing every time you needed to remove the shift rod. I used double nuts on the rear, to make it easy to remove the bearing from the rear. When going to a 915 gear box, PMS sells a tunnel shift rod that is not adjustable. The adjustment as far as I know is done with the rear shift rod. There rear shift rod is designed for a Wevo. I went with Martin's 916 kit, so I bought Chris's adjustable tunnel shift rod. The adjustable shift rod works great with my 916 trans setup. |
Lo-Fi Version | Time is now: 28th May 2024 - 05:10 PM |
