where o where is a 30m oil pump ?, ...and cover |
rush |
May 21 2015, 11:56 PM
Newbie Group: Members Posts: 25 Joined: 15-May 15 From: orcas island, wa Member No.: 18,731 Region Association: None |
where can I find a 30mm oil pump..w/ cover
I do a search and every parts house in the lower 48 says they have ...only to find what they have is a o ring or a gasket or lock...but no pump (IMG:style_emoticons/default/confused24.gif) |
mr914 |
May 22 2015, 02:59 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
There was an aftermarket pump..
Think the brand was melling, had on caused all kinds of havoc. Along with the high pressure oil piston kit. Steve, the freak, built a super vee spec motor for me. And I ran the car at heartland park Topeka at a PCA event... Damn, that was a fun motor, ran like a rotary, no torque curve, from 2000-7250. Limited by msds, 6AL... Filled the puke can, overflowed it... Cracked a cooler/fitting/adapter.... Made oil come from every oraface. Valve covers, oil cooler seals, oil fill seal Poor Denny lapping behind me in his '89 turbo look. 23k miles, concourse car. Sprayed a few other cars as wheel that weekend. Rather misted (IMG:style_emoticons/default/hissyfit.gif) Hence my 71' track car was known as the "914 from hell" My apologies to those that I sprayed for the hours that you spent with a qtip, re-detailing your car. Yes it was fun, but I personally think that using a melling or other high performance oil pump is not worth the aggravation. Now, if I was running a bus in a high torque low rpm application in the mojave desert, that would be a completely different application, and that pump could work for the 10 extra quarts of oil to keep everything cool. My 2 cents. Your mileage may vary, depending on your driving conditions, octane and driving style.... |
0396 |
May 22 2015, 03:31 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
where can I find a 30mm oil pump..w/ cover I do a search and every parts house in the lower 48 says they have ...only to find what they have is a o ring or a gasket or lock...but no pump (IMG:style_emoticons/default/confused24.gif) I believe that FAT Performance in Orange County California has what you are looking for. |
Madswede |
May 22 2015, 05:39 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
Not to pick on the obvious typo in the subject header, but I was thinking to myself, "how can you miss a 30 meter oil pump?!" (IMG:style_emoticons/default/blink.gif)
rush |
May 22 2015, 08:50 PM
....it was underneath the 700 metre car
Jake Raby |
May 23 2015, 09:21 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
They have their place.. Open clearances inside engines can use the added volume.
The only think I like about them is the pump body doesn't expand like aluminum, so the clearance between the gears and pump body stays tighter. The negative is the engine case expands more greatly than the pump body. If you find one for a VW type 1 for an "A" cam gear, then its the same as the unit for the T4. |
rush |
May 24 2015, 01:08 PM
Jake thanks info !
Lo-Fi Version | Time is now: 3rd May 2024 - 07:58 PM |
