where o where is a 30m oil pump ?, ...and cover |
rush |
May 21 2015, 11:56 PM
Newbie Group: Members Posts: 25 Joined: 15-May 15 From: orcas island, wa Member No.: 18,731 Region Association: None |
where can I find a 30mm oil pump..w/ cover
I do a search and every parts house in the lower 48 says they have ...only to find what they have is a o ring or a gasket or lock...but no pump (IMG:style_emoticons/default/confused24.gif) |
mr914 |
May 22 2015, 02:59 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
There was an aftermarket pump..
Think the brand was melling, had on caused all kinds of havoc. Along with the high pressure oil piston kit. Steve, the freak, built a super vee spec motor for me. And I ran the car at heartland park Topeka at a PCA event... Damn, that was a fun motor, ran like a rotary, no torque curve, from 2000-7250. Limited by msds, 6AL... Filled the puke can, overflowed it... Cracked a cooler/fitting/adapter.... Made oil come from every oraface. Valve covers, oil cooler seals, oil fill seal Poor Denny lapping behind me in his '89 turbo look. 23k miles, concourse car. Sprayed a few other cars as wheel that weekend. Rather misted (IMG:style_emoticons/default/hissyfit.gif) Hence my 71' track car was known as the "914 from hell" My apologies to those that I sprayed for the hours that you spent with a qtip, re-detailing your car. Yes it was fun, but I personally think that using a melling or other high performance oil pump is not worth the aggravation. Now, if I was running a bus in a high torque low rpm application in the mojave desert, that would be a completely different application, and that pump could work for the 10 extra quarts of oil to keep everything cool. My 2 cents. Your mileage may vary, depending on your driving conditions, octane and driving style.... |
Lo-Fi Version | Time is now: 17th May 2024 - 07:45 PM |
