where o where is a 30m oil pump ?, ...and cover |
rush |
May 21 2015, 11:56 PM
Newbie Group: Members Posts: 25 Joined: 15-May 15 From: orcas island, wa Member No.: 18,731 Region Association: None |
where can I find a 30mm oil pump..w/ cover
I do a search and every parts house in the lower 48 says they have ...only to find what they have is a o ring or a gasket or lock...but no pump (IMG:style_emoticons/default/confused24.gif) |
Jake Raby |
May 23 2015, 09:21 AM
They have their place.. Open clearances inside engines can use the added volume.
The only think I like about them is the pump body doesn't expand like aluminum, so the clearance between the gears and pump body stays tighter. The negative is the engine case expands more greatly than the pump body. If you find one for a VW type 1 for an "A" cam gear, then its the same as the unit for the T4. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:08 AM |
