Setrab oil cooler, Can two small ones be run in series? |
rtalich |
May 22 2015, 07:50 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Ordered the smaller setrab unit with fan to replace the oil cooler that was installed when I bought the car (pictures). The new setrab unit is way smaller than I thought it would be. In fact, it's about half the size of what's installed now. I'm pretty sure the bigger setrab unit with the double fans is too big for this space. Anyone see issues if I run two of these smaller units in series? That way I can install them staggered and will fit in that space quite nicely.
Attached thumbnail(s) |
McMark |
May 22 2015, 08:12 PM
Yes, but running them in parallel is better.
screenguy914 |
May 22 2015, 09:11 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Yes, but running them in parallel is better. You sure? Running coolers in parallel, oil will take the path of least resistance. I suggest running in series, and maybe at least one in a better location for air flow, like in front. What size is the AN hose? Should be at least -12. Sherwood |
stugray |
May 22 2015, 09:42 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Yes, but running them in parallel is better. You sure? Running coolers in parallel, oil will take the path of least resistance. I suggest running in series, and maybe at least one in a better location for air flow, like in front. What size is the AN hose? Should be at least -12. Sherwood I thought about this very issue. I put two of the smallest setrabs you can buy below the headlight buckets and vented through the foglamp holes. I put them in series. I considered the parallel idea, but decided that there would be no way to know if you had even flow through both that way. And I used 12AN for the full run to the front & back. |
Andyrew |
May 26 2015, 01:17 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Yes, but running them in parallel is better. You sure? Running coolers in parallel, oil will take the path of least resistance. I suggest running in series, and maybe at least one in a better location for air flow, like in front. What size is the AN hose? Should be at least -12. Sherwood I thought about this very issue. I put two of the smallest setrabs you can buy below the headlight buckets and vented through the foglamp holes. I put them in series. I considered the parallel idea, but decided that there would be no way to know if you had even flow through both that way. And I used 12AN for the full run to the front & back. Stu, You got pics of this? I am curious of the fit (IMG:style_emoticons/default/smile.gif) |
stugray |
Jun 14 2015, 01:03 PM
The best documentation of the build is in this thread: http://www.914world.com/bbs2/index.php?sho...6102&st=240 (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1389661344.7.jpg) |
Lo-Fi Version | Time is now: 12th May 2024 - 11:20 AM |
