Setrab oil cooler, Can two small ones be run in series? |
rtalich |
May 22 2015, 07:50 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Ordered the smaller setrab unit with fan to replace the oil cooler that was installed when I bought the car (pictures). The new setrab unit is way smaller than I thought it would be. In fact, it's about half the size of what's installed now. I'm pretty sure the bigger setrab unit with the double fans is too big for this space. Anyone see issues if I run two of these smaller units in series? That way I can install them staggered and will fit in that space quite nicely.
Attached thumbnail(s) |
rtalich |
Jun 15 2015, 06:26 PM
Well... It was pretty warm today... 80 degrees out. Oil temp got up to 270!!! Found out when I got home that I forgot to hook up the gnd wire for the fan!! Pretty sure fans work better when they are hooked up to power correctly.
DRPHIL914 |
Jun 16 2015, 06:58 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Well... It was pretty warm today... 80 degrees out. Oil temp got up to 270!!! Found out when I got home that I forgot to hook up the gnd wire for the fan!! Pretty sure fans work better when they are hooked up to power correctly. (IMG:style_emoticons/default/new_shocked.gif) on saturday here it was between 85 early and 95 later, and my 2.0 was pushing 235 and i was concerned about that. I am using Valvoline VR1, now, but otherwise the Gibbs oil Jake recommends and so i would immagine that it is formulated for temps like that - anyway ive been considering doing one of thse set ups as well to try and get those temps a bit lower, because that was just flat land driving. and ive been told that 220 would be a better running temp to hold under performance driving. So my question is, what will a set up like this run cost wise? and can a novice like myself do the work?(i've done most everything on this car myself so far-thanks to the World) or am i better off taking over to the local shop?(Bob Woodman-experienced 911 performance and racing shop). thank, and sorry for the hijack... |
Lo-Fi Version | Time is now: 12th May 2024 - 04:26 PM |
