Setrab oil cooler, Can two small ones be run in series? |
rtalich |
May 22 2015, 07:50 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Ordered the smaller setrab unit with fan to replace the oil cooler that was installed when I bought the car (pictures). The new setrab unit is way smaller than I thought it would be. In fact, it's about half the size of what's installed now. I'm pretty sure the bigger setrab unit with the double fans is too big for this space. Anyone see issues if I run two of these smaller units in series? That way I can install them staggered and will fit in that space quite nicely.
Attached thumbnail(s) |
rtalich |
Jun 15 2015, 06:26 PM
Well... It was pretty warm today... 80 degrees out. Oil temp got up to 270!!! Found out when I got home that I forgot to hook up the gnd wire for the fan!! Pretty sure fans work better when they are hooked up to power correctly.
stugray |
Jun 16 2015, 07:59 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Well... It was pretty warm today... 80 degrees out. Oil temp got up to 270!!! Found out when I got home that I forgot to hook up the gnd wire for the fan!! Pretty sure fans work better when they are hooked up to power correctly. That sounds REALLY hot for driving around town. I start getting nervous with anything above 250 oil temps and that is racing which is ~20 minutes of WOT. I got to 250 with a brand new engine rebuild on the track and no external oil coolers (stock cooler only). Then I plumbed in the front coolers (which also adds ~3 quarts extra) and cant get my temps UP TO 200 without driving hard. With my front oil coolers TAPED OVER, I havent seen oil temps get even UP TO 220 yet this year with full track time. |
Lo-Fi Version | Time is now: 13th May 2024 - 10:24 AM |
