Setrab oil cooler, Can two small ones be run in series? |
rtalich |
May 22 2015, 07:50 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Ordered the smaller setrab unit with fan to replace the oil cooler that was installed when I bought the car (pictures). The new setrab unit is way smaller than I thought it would be. In fact, it's about half the size of what's installed now. I'm pretty sure the bigger setrab unit with the double fans is too big for this space. Anyone see issues if I run two of these smaller units in series? That way I can install them staggered and will fit in that space quite nicely.
Attached thumbnail(s) |
era vulgaris |
Jun 16 2015, 08:26 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Not the best pic, but the only one I have of my setup (taken from the PO's FS listing, but the setup hasn't changed).
Setrab oil cooler with a pair of 5" Spal puller fans. Fans are activated via a 180 degree thermostatic switch, and I've also got the Tangerine inline oil cooler bypass so nothing goes to the oil cooler until temps get up. The front of the cooler has a manifold with two inlets that attaches to the orange ducting. There's a NACA duct in the rocker feeding one of the inlets, and the other inlet is fed via fresh air from the engine grill. This setup is actually too good. I have to beat the shit out of the car to get oil temps over 200. Typical around town driving has me at 160-180. I actually need to figure out a way to get my oil temps higher! I've tried removing the ducting, so that the oil cooler is only fed by the air flowing under the car, but the impact was only minimal. And this is in 90+ degree NC summer weather. I've been thinking about getting rid of the fans. Attached image(s) |
maf914 |
Jun 17 2015, 07:22 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Setrab oil cooler with a pair of 5" Spal puller fans. Era Vulgaris, What size or model number Setrab cooler are you using? Thanks. Attached image(s) |
era vulgaris |
Jun 17 2015, 11:53 AM
Setrab oil cooler with a pair of 5" Spal puller fans. Era Vugaris, What size or model number Setrab cooler are you using? Thanks. Had to dig through the box of receipts the PO gave me! (IMG:style_emoticons/default/biggrin.gif) Setrab STD 134 bought from Elephant Racing. I'm not currently seeing it on their website, (maybe it's NLA?) but they do have sizes that are close. http://www.elephantracing.com/oilhandling/...aboilcooler.htm |
Lo-Fi Version | Time is now: 12th May 2024 - 09:31 AM |
