1974 914-4 2.0, Tackling the rust |
Nemisus |
May 25 2015, 03:53 PM
Member Group: Members Posts: 82 Joined: 1-October 11 From: North Bay CA Member No.: 13,631 Region Association: Northern California |
Now that I have the 2.0 running adequately its time to tackle the rust issues...
When I first looked this car over I was so excited about getting it I didn't look as thoroughly as I should have. The cost of excitement I suppose... Although what I am about to show you isn't nearly as bad as some of the amazing restorations I have seen on this site, I still feel it is necessary to show you what I am dealing with! My hopes are that I can be pointed in the right direction. I am partially embarrassed to even show these pictures as the rot is minimal by comparison to what I've seen some members work with... here goes nothing... all the interior removed: (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432590830.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432590831.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432590831.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432590831.4.jpg) seat mount is completely gone: (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432590832.5.jpg) Just behind the passenger seat... directly over the jack mount area: (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432590832.6.jpg) Same area as from the previous pictures only look from under: (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432591623.1.jpg) nearly completely separated from the top of the tunnel: (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1432590832.7.jpg) Nemi |
Nemisus |
Jul 13 2015, 05:27 PM
Pull that pressure plate and make sure the clutch is in good shape while you're there. This will also make sure it's free. In some cases the flywheel clutch and pressure plate will stick/rust together. Happened to me on a Datsun 280Z once. Good call Mark! I was looking at the last night and had a hell of a time getting the bolts to loosen up. Is there a special thin walled socket that is used? Considering that this sat for 6 years I'd image a replacement would only benefit. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:34 PM |
