Front clip...where to cut? |
billh1963 |
May 26 2015, 09:28 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I'm going to start stripping my two rusty parts cars in the next couple of weeks. The yellow 74 actually has (upon initial inspection) a decent front tub. I would hate to scrap it if it can be used. Is there an optimal place to cut or just cut off the front end forward of the rusty area? (IMG:style_emoticons/default/smile.gif)
I assume a sawzall and plenty of blades will do the job? |
Chris H. |
May 26 2015, 10:19 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Seems like the fewest blades would be used if you cut just behind the front door jamb straight across. Zip through the long, across the floor pan, center tunnel, other long, done. It'll be a big piece...but someone will use it. Sawzall will do just fine.
Chris Pincetich |
May 26 2015, 10:26 AM
Save the front cowel (IMG:style_emoticons/default/beerchug.gif) |
Kansas 914 |
May 26 2015, 10:27 AM
I have seen Rick Ollah do this in my garage on a donor I had. You might check with him as well.
billh1963 |
May 26 2015, 10:45 AM
Thank you for the replies. That makes sense....then if someone needed a particular section they could "pick and choose" what they need.
DRPHIL914 |
May 26 2015, 11:46 AM
plasma cutter.. (IMG:style_emoticons/default/poke.gif)
also i could see some very intersting yard art in your future, not sure if your neighbors would appreciate it. - |
May 26 2015, 02:50 PM
The woman in CA needs both front fenders and front trunk floor.
Might want to see if that will work out for you to cut it for that use. rich |
cary |
May 26 2015, 09:42 PM
My rustoration is a front clip car. It was cut about 9 inches from the door hinge post.
scotty b |
May 27 2015, 11:48 AM
cut just behind the exhaust tip (IMG:style_emoticons/default/mellow.gif)
billh1963 |
May 27 2015, 12:37 PM
Lo-Fi Version | Time is now: 16th May 2024 - 09:40 AM |
