FS: USED Extra Nice Axle, Steering Parts SOLD, 951Turbo Stub Axles, Control Arm Shafts Upper steering shaft |
914Sixer |
May 27 2015, 06:53 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
951 Turbo Stub Axles for those wanting to do 100 mm CV Joints. They will require spacer washer. $62 shipped
Control Arm Shafts $62 shipped Upper Steering Shaft $17 shipped Paypal: a914nut@email.com Attached image(s) |
914Sixer |
May 30 2015, 08:41 AM
Old Yella |
May 30 2015, 04:27 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
Hi
I need some rear shafts, Are they factory or after market? |
bdstone914 |
May 30 2015, 06:04 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi Mark,
Do you need an extra spacer under the nut or on the back side ? And your parts are way too clean. Your setting a bad example for the rest of us. Bruce |
914Sixer |
May 30 2015, 06:38 PM
Spacer goes on the axle shaft bottom to support the bearing because the shelf has been machined off. See the Classic Threads for 944 CV joint installation. Shows location and gives size required. The 951 axles where close to cherry when I got them.
Axle shafts are stock 914 and they are used but in very good condition. I try and sell the best I can get. |
gcrotvik |
May 31 2015, 11:30 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I will take the pivot shafts if available. PM sent.
914Sixer |
May 31 2015, 11:58 AM
Shafts are sold to Greg.
914Sixer |
Jun 4 2015, 04:34 PM
Stub axles still available.
tgranger3 |
Jun 4 2015, 07:45 PM
Newbie Group: Members Posts: 1 Joined: 1-January 15 From: Austin, Texas Member No.: 18,276 Region Association: None |
Do you have rear control arms for sale?
Thanks, Tom |
914Sixer |
Jun 14 2015, 07:17 AM
951 stub axles are sold.
Lo-Fi Version | Time is now: 25th April 2024 - 09:41 PM |
