914Sixer
May 27 2015, 06:53 PM
951 Turbo Stub Axles for those wanting to do 100 mm CV Joints. They will require spacer washer. $62 shipped
Control Arm Shafts $62 shipped
Upper Steering Shaft $17 shipped
Paypal: a914nut@email.com
914Sixer
May 30 2015, 08:41 AM
Old Yella
May 30 2015, 04:27 PM
Hi
I need some rear shafts, Are they factory or after market?
bdstone914
May 30 2015, 06:04 PM
Hi Mark,
Do you need an extra spacer under the nut or on the back side ?
And your parts are way too clean. Your setting a bad example for the rest of us.
Bruce
914Sixer
May 30 2015, 06:38 PM
Spacer goes on the axle shaft bottom to support the bearing because the shelf has been machined off. See the Classic Threads for 944 CV joint installation. Shows location and gives size required. The 951 axles where close to cherry when I got them.
Axle shafts are stock 914 and they are used but in very good condition. I try and sell the best I can get.
gcrotvik
May 31 2015, 11:30 AM
I will take the pivot shafts if available. PM sent.
914Sixer
May 31 2015, 11:58 AM
Shafts are sold to Greg.
914Sixer
Jun 4 2015, 04:34 PM
Stub axles still available.
tgranger3
Jun 4 2015, 07:45 PM
Do you have rear control arms for sale?
Thanks,
Tom
914Sixer
Jun 14 2015, 07:17 AM
951 stub axles are sold.
