76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,786 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
OK, the 20th sounds good. Unless that shakes the majority, lets run with it. I'll recheck this tonite when I get home and confirm the date. (IMG:style_emoticons/default/piratenanner.gif) We don't have a Wine Tasting Avatar, do we?
914-300Hemi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California ![]() ![]() |
Sounds fun. wife and I are good for June 20th.
Alphaogre |
Member ![]() ![]() Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California ![]() |
I'd be in pending the date. June 20 is PCA auto cross...
Cuda911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California ![]() |
^^^ Chris, I'll be at the June 20 autocross too.
76-914 |
As always there is no perfect date and the 20th appears to be the best for this event. I wish the PCA would have picked another date but there's no reason we can't do this again in Autumn.
So here is the plan: Lunch 12-1 arrive a little early for 914 "mind melt" and BS sessions. I won't be serving any alcoholic beverages as we will be having wine after lunch. (IMG:style_emoticons/default/piratenanner.gif) 1-3 Wine Tasting Tour Attendee's (so far): Eddie and Munda Ethan K. + 1 Paul K. + 1 Cesar + 1 Don-6 + 1 Forrest/ Susan Ravi + 1 |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
Susan and I will attend if I can get my new motor sorted out and road-tested prior to the 20th. As of yesterday, the motor is in and running but has an untested side shifter tranny to be hooked up today and a weird ignition wire issue with no juice to the fuel pump???.
(IMG:style_emoticons/default/beerchug.gif) |
76-914 |
Susan and I will attend if I can get my new motor sorted out and road-tested prior to the 20th. As of yesterday, the motor is in and running but has an untested side shifter tranny to be hooked up today and a weird ignition wire issue with no juice to the fuel pump???. (IMG:style_emoticons/default/beerchug.gif) How'd did you get it started with a non-working fuel pump? (IMG:style_emoticons/default/confused24.gif) You have 3 weeks; I'm sure you'll have things sorted out by that point. (IMG:style_emoticons/default/beerchug.gif) |
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,533 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
Munda and I are in. (IMG:style_emoticons/default/beer3.gif) (seven)
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Thanks for setting this up Kent, but Susan and I can't do that weekend.
don-6 |
Stock vs Modified? ![]() ![]() Group: Members Posts: 172 Joined: 7-April 14 From: Conroe, TX Member No.: 17,219 Region Association: Southwest Region ![]() |
The 20th works for us. Tina and I are looking forward to seeing everyone, and tasting some Vino! (IMG:style_emoticons/default/drunk.gif)
Don |
Cuda911 |
76-914 |
Thanks for setting this up Kent, but Susan and I can't do that weekend. Well Horse Feathers. I figured someone would get shot down. We'll do it again come late Oct/early Nov. I'll get a final head count later this week then call the 1st five wineries on my list to be sure they can accommodate us reasonably well. Who knows; some may be interested in having a few collector cars on their lot (IMG:style_emoticons/default/confused24.gif) ? |
76-914 |
We're getting close so I need a "Head Count". Please refer to post #25. If you need your name added or deleted, let me know. Now for the teaser. Last weekend I did a brisket on my new smoker and OMG, 18 hr's later, you could cut it with a plastic fork. Think I'll throw in some Hot Links, Roasted Corn on the Cobb, Homemade Potato Salad and Banana Pudding. (IMG:style_emoticons/default/chowtime.gif)
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Too far to travel to drink bad wine. (IMG:style_emoticons/default/av-943.gif)
914_teener |
Unless it.s in Carlsbad that day.....cannot make it. Thanks though Kent.
76-914 |
(IMG:style_emoticons/default/poke.gif) So how far do you usually travel for bad wine, Elyut? Besides, our wines aren't half bad. Here is another shocker. I had some tasty Texas Wine last year. The Journey's never too far nor the Spirits imperfect when combined with friends. (IMG:style_emoticons/default/beerchug.gif) Unless it.s in Carlsbad that day.....cannot make it. Thanks though Kent. Understood. Maybe you can join us for the next one. |
Blue6 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,055 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California ![]() ![]() |
Kent, we won't be able to make it this time either. It's going to be to cold in Temecula, so we're going to Lake Havasu. (IMG:style_emoticons/default/biggrin.gif)
sb914 |
Kent, we won't be able to make it this time either. It's going to be to cold in Temecula, so we're going to Lake Havasu. (IMG:style_emoticons/default/biggrin.gif) You were just there two weeks ago! I guess he dont like to hang with us. (IMG:style_emoticons/default/poke.gif) |
76-914 |
Kent, we won't be able to make it this time either. It's going to be to cold in Temecula, so we're going to Lake Havasu. (IMG:style_emoticons/default/biggrin.gif) You were just there two weeks ago! I guess he dont like to hang with us. (IMG:style_emoticons/default/poke.gif) You and Munday are still in Eddy, right? |
sb914 |
Kent, we won't be able to make it this time either. It's going to be to cold in Temecula, so we're going to Lake Havasu. (IMG:style_emoticons/default/biggrin.gif) You were just there two weeks ago! I guess he dont like to hang with us. (IMG:style_emoticons/default/poke.gif) You and Munday are still in Eddy, right? Yep we're in.I'll call ya when we leave . |
Lo-Fi Version | Time is now: 1st September 2025 - 07:17 AM |
