2 versions of the "nozzle" / dash side vent control, what is the MY for these? |
type47 |
May 28 2015, 04:18 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I have 2 versions of the air vent at the ends of the MY 73 dash (correct me if wrong MY). Pics below. Is there a changeover MY? I want to use the correct ones for a '73. Bottom pic is from a 74
eric9144 |
May 28 2015, 10:11 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I have a '74 MY build date 10/73, it has the second version you show with the lever at the top.
JeffBowlsby |
Jun 4 2015, 09:28 PM
914 Wiring Harnesses Group: Members Posts: 8,492 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Top photo is correct for the 1973. Bottom photo for the 1974.
BillC |
Jun 30 2015, 01:00 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
My '73 1.7 has the second style vents. I don't know the build date because the door jamb sticker is missing, but am fairly certain my car was built toward the end of the '73 MY.
Given the originality of the rest of the interior of my car, I have no reason to suspect the vents were changed. So, I suspect this another case where the factory started switching over to the new parts when they felt like it, rather than exactly at the start of the next MY. I do have the CoA on order, but it's only been a month, so no idea when it will finally arrive. |
914Next |
Jun 30 2015, 07:46 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
My '73 1.7 has the second style vents. I don't know the build date because the door jamb sticker is missing, but am fairly certain my car was built toward the end of the '73 MY. Given the originality of the rest of the interior of my car, I have no reason to suspect the vents were changed. So, I suspect this another case where the factory started switching over to the new parts when they felt like it, rather than exactly at the start of the next MY. I do have the CoA on order, but it's only been a month, so no idea when it will finally arrive. Mine also is a '73 with 100% original interior and has the vent that is described as the '74 version. Mine was a later '73 build (april) but clearly at lease some of the '74 version made it into production '73 cars. |
type47 |
Jul 2 2015, 04:44 AM
Hmmm, well, since I have 2 vents in hand, I'm gonna use what I have. 4732914137 (the car that will get these) sounds like a later car to me.
PancakePorsche |
Jul 9 2015, 12:38 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Mid year change. My early 73 is just like a 72. Has early doors, vents, fog lights, and green fog switch. Also has unusual vinyl covered windshield frame/ A-pillars. After March or so 73's mostly same as 74.
Your car could either depending on build date. |
23e Heure |
Jan 11 2016, 04:26 AM
Busy overtaking 911s Group: Members Posts: 323 Joined: 13-August 15 From: London Member No.: 19,057 Region Association: England |
Sorry to hi-jack the thread.
I need a replacement vent for my 1974 build car. Are these available as new / repros, or do I need to source a used one? Thanks! |
23e Heure |
Jan 21 2016, 04:14 AM
Bump to see if anyone knows where I might get hold of a replacemnt vent for my '74.
Looking at the photos on this thread, I realise the ones in my car are currently fitted upside down (ie levers at the bottom)! |
Lo-Fi Version | Time is now: 10th May 2024 - 04:25 AM |
