What kind of ignition are you running?, Coil,wires, boxes... |
blk'72 |
Feb 22 2005, 12:34 AM
Member Group: Members Posts: 83 Joined: 2-November 04 From: Pleasanton, CA Member No.: 3,053 |
Hey all what are you running for the spark?
CAn we see some pics... Is all the vw going to work on our engines? I am thinking about redoing the whole system, I have some crazy backfirin'!!! (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) thnks R. |
Type 4 |
Feb 22 2005, 12:40 AM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Kettering
Mueller |
Feb 22 2005, 01:16 AM
stock D-jet with billet alumium Mallory Unilite dizzy, grey/grey springs..8.5mm plug wires
Brando |
Feb 22 2005, 01:29 AM
Stock for a 1.8 with AFC (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Aaron Cox |
Feb 22 2005, 01:31 AM
Mallory Unilite, Mallory Hyfire VI A, Magnecore 8.5mm wires, mallory promaster coil, bosch plugs.....
Trekkor |
Feb 22 2005, 01:36 AM
Post the stinkin' pics...WOW!!! KT |
Aaron Cox |
Feb 22 2005, 01:38 AM
send me megaphones and ill steal a camera to post pics.... LOL (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
Trekkor |
Feb 22 2005, 01:46 AM
You already know how to get the megs and air dam for free. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
KT |
Trekkor |
Feb 22 2005, 02:03 AM
Will be MSD6AL, Pertronix Ignitor, Bosch Blue coil, NGK plugs.
KT |
J P Stein |
Feb 22 2005, 03:25 AM
Well, it's your car, do what you want.....but what you need is a MSD high vibration coil. Gap them NGKs at .045-.050. The Blue coil won't cut the mustard. .....and no, I won't explain it. Take some time and cruise thru here: http://www.rennsportsystems.com/ |
72914S |
Feb 22 2005, 06:36 AM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
MSD 6AL w/7000 rpm pill (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) ,8.5 mm wires, bosch plugs (gaped@.45). Soon to add Crane 700,MSD Blaster 2 coil.
machina |
Feb 22 2005, 07:00 AM
Mallory Unilite, Mallory HyFire VI-AL, Aurora 8.5mm, Bosch Blue........ Attached thumbnail(s) |
Mark Henry |
Feb 22 2005, 07:27 AM
what's a dizzy???? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
ArtechnikA |
Feb 22 2005, 07:29 AM
Crane Hi-6, programmable rev limit set at 7100; Crane 700 optical points replacement, LX-92 pulse transformer ("coil"), Magnecore wires, NGK or Denso (i don't recall which i put in there last) Iridium plugs. retard controller dials in 5-deg of retard on overrun and for starting.
lost the drivers for my scanner in the upgrade to XP, as soon as i can find a set i'll scan in some pictures... |
CptTripps |
Feb 22 2005, 07:34 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Whow....Some serious electronic gear here.
What would I gain by going to an electronic setup like that? |
Mark Henry |
Feb 22 2005, 08:17 AM
My set up is a SDS EM4F, programable FI and spark
My curve is like a bell curve, 10d BTDC at idle, between 1700-3000 it goes to 28d total, then at 4500 it begins to retard to 24d total. The last bit was something that Jake noticed with the Kit Carson system...it really wakes up the engine in the higher RPM's. The nice thing about programable ignition (crank trigger) is you can change the curve in seconds. |
Kerrys914 |
Feb 22 2005, 09:07 AM
Not running yet but it will have when it does (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
- Crane Hi-6 - Crane XR700 - Crane PS-91 Coil - NGK plugs - Need to buy some wires (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Cheers |
nickg |
Feb 22 2005, 09:44 AM
Senior Member Group: Members Posts: 501 Joined: 30-August 04 From: franklin, nj Member No.: 2,652 |
will the msd replace the stock cd unit on a 914-6? i am doing a conversion and I have the stuff from a 914-6
ArtechnikA |
Feb 22 2005, 09:57 AM
yes - you can remove the stock "ignition harness" and use the same connections. the Bosch CDI box has 3 terminals - +12V in (power), line from the points, line back to the coil. MSD has sorta the same - use the old power wire as the "switched +12" and then you have only from the points and to the coil to deal with. use a GOOD ground and wire the big red wire to the battery. |
Steve Thacker |
Feb 22 2005, 10:01 AM
UMMMPH Yea Baby Yea ! UMMMPH Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
Holy smokes that is nice Mark. What sort of setup is that? Did you get those off another type of car? I love how clean looking it is. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Never mind Mark I asked too late....just now saw your post. I'd love to do that, but don't know what to buy or know the cost to convert. I'm Stock F.I with Crane XR700 trigger |
Lo-Fi Version | Time is now: 18th May 2024 - 10:41 AM |
