Vacuum line question, From the Y to the aux air reg. |
74ravenna |
May 30 2015, 10:19 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
Its been a while since I started replacing the vacuum lines on my 74 1.8.
So now that I'm back at it I'm wondering if I have the section from the air filter (upper part of throttle body?) to the Y then down to the Aux Air Regulator done correctly. Why is there a metal sleeve before the auxiliary air regulator? Why not one piece of hose from the Y down to the Regulator? When I look online at Peter Klager's layout, his diagram does not show that metal sleeve. Did a prior owner do this or is this correct from the factory? |
type47 |
May 30 2015, 12:05 PM
If I'm not mistaken, there is a rubber elbow used there. 022.129.637 from the PET
Or possibly 021.129.639 could be used |
74ravenna |
May 30 2015, 02:14 PM
If I'm not mistaken, there is a rubber elbow used there. 022.129.639 from the PET Or possibly 021.129.639 could be used Wow! You're so right. I have to admit of my blunder here. I have two elbows on the way from another forumite and totally forgot. Thats a little scary. Thanks. Steve |
boxsterfan |
May 30 2015, 11:32 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Early 1974 1.8L vacuum hose layout:
http://bowlsby.net/914/Classic/zTN_FI_Hose...L_Early1974.jpg Late 1974+ 1.8L vacuum hose layout: http://bowlsby.net/914/Classic/zTN_FI_Hose...Late1974-75.jpg |
Lo-Fi Version | Time is now: 16th May 2024 - 12:51 PM |
