Its been a while since I started replacing the vacuum lines on my 74 1.8.
So now that I'm back at it I'm wondering if I have the section from the air filter (upper part of throttle body?) to the Y then down to the Aux Air Regulator done correctly.
Why is there a metal sleeve before the auxiliary air regulator? Why not one piece of hose from the Y down to the Regulator?
When I look online at Peter Klager's layout, his diagram does not show that metal sleeve.
Did a prior owner do this or is this correct from the factory?
