When removing the backpad,, and carpeting the firewall... |
mike_the_man |
Feb 22 2005, 02:17 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
What does everybody do with the interior light, etc? I'm assuming just remove it. I think that I have a few other wires running around behind the back pad from the PO as well. Whats the best procedure for doing this? What type of glue is good to use? Lets hear some tips, and any pics would be appreciated as well.
bondo |
Feb 22 2005, 02:21 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I'm replacing mine with lights built into a rearview mirror.
mike_the_man |
Feb 22 2005, 02:39 PM
Good idea. I was thinking about that too. What sort of mirror are you using? I know that Mustang convertibles have a mirror like that.
SteveSr |
Feb 22 2005, 02:59 PM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
Same here,using the one out of the doner car i took the V6 from ...1991 chevy Corsica. SteveSr |
horizontally-opposed |
Feb 22 2005, 03:40 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I wonder if (a more effective one) could be worked into the targa bar front pad. The trick would be making it look good, maybe tucked in at an angle on the pad's lower surface, back near the glass?
pete |
mike_the_man |
Feb 22 2005, 03:49 PM
Good idea Pete, I hadn't thought of that. I'll have to have a look. I bet something could be done.
Brad Roberts |
Feb 22 2005, 03:52 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
My truck has flush mounted "directional" lights (you can move them) mounted in the overhead console. Some of these mounted in the targa pad (under the targa bar, not in front of it) would be trick. Show us some pics..
B |
mike_the_man |
Feb 22 2005, 04:06 PM
I like it Brad. Should be able to find some lights like that at the local pick a part.
Long time no see, Brad. How are you doing? Busy as always, I'm sure. |
xsboost90 |
Feb 22 2005, 04:14 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
what about making a center piece made of spray foam, shaping it, installing the light and then gluing it on, and carpeting over that?
Lo-Fi Version | Time is now: 26th May 2024 - 11:08 PM |
