fixing/replacing a clutch cable?, anybody run across this? pics included |
theleschyouknow |
Jun 2 2015, 07:18 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
as mentioned in another thread my clutch pedal popped and dropped to floor the other day so I assume it's broken clutch cable
fast forward to today and I am attempting to replace after I got the pedal board removed (that's fun with a center console) I had to go fishing in the tunnel access area to find pedal end with the clevis on it and when I got it here's what I found hard to tell in the pic but in situ (it looks to me like) it's considerably opened wider than it should ??? anybody run into this before and can I just bend it back into place? (IMG:style_emoticons/default/mad.gif) never mind I just broke it trying to squeeze it back together with my fingers!!! anybody got an extra clevis part to sell? will post a wtb in classifieds thanks cjl |
Mike Bellis |
Jun 2 2015, 07:38 PM
I think you can buy these new instead of using s 40 year old used piece.
steuspeed |
Jun 2 2015, 07:54 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Yeah isn't that fun with the console in there? Mine was installed backwards, so it was even harder to get out. You need a new clevis fork and pin? Ebay and AutoAtlanta has them. I'm sure other places too.
theleschyouknow |
Jun 2 2015, 08:09 PM
yep y'all are probably right better to just order a new one -if my 40 year old one is fatigued I imagine they all are
out of curiosity anybody seen this before? is it indicative another issue? like bad bushings or something else? clutch pedal worked great prior not sticky or hard to engage at all |
malcolm2 |
Jun 2 2015, 09:31 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
probably a Grainger or McMaster-Carr item.
brant |
Jun 2 2015, 10:26 PM
I have had it happen on the race car
But I assumed it was related to the high pressure of the Tilton clutch. Haven't seen it on my street car. |
walterolin |
Jun 2 2015, 10:31 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Google this P/N: 90016600202. About 5.00 USD, several vendors.
bandjoey |
Jun 2 2015, 10:53 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
http://www.ebay.com/itm/PORSCHE-CLUTCH-CAB...A-/190687600634
Autohaus, pelican, possibly Zims locally ( phone call...they have 914 parts not in their online site), and others. U can visually check the shift rod bushings. If you have trouble adjusting the clutch / shifting many times it's the bushings. (IMG:style_emoticons/default/smash.gif) |
theleschyouknow |
Jun 8 2015, 04:51 PM
my trained monkey was on strike but after much cussing and contorting I got the clevis hooked up to the pedal. while I was under there and waiting on parts I decided to clean up the oil and gunk from the trans and engine (+1 for Awesome cleaner from the dollar store/dollar general -thanks 914world collective!)
so while cleaning I discovered my plastic or rubber rear shift cover is cracked -it's a sideshift- anybody know where to get one? I've check pelican aa gpr Sierra madre .... all seem to be NLA I think it was patrick motor sports that has what I think is the right part but no pic so I'm not sure. anyone know if 914rubber makes these? cjl |
stugray |
Jun 8 2015, 05:02 PM
as mentioned in another thread my clutch pedal popped and dropped to floor the other day so I assume it's broken clutch cable fast forward to today and I am attempting to replace after I got the pedal board removed (that's fun with a center console) I had to go fishing in the tunnel access area to find pedal end with the clevis on it and when I got it here's what I found hard to tell in the pic but in situ (it looks to me like) it's considerably opened wider than it should ??? anybody run into this before and can I just bend it back into place? (IMG:style_emoticons/default/mad.gif) never mind I just broke it trying to squeeze it back together with my fingers!!! anybody got an extra clevis part to sell? will post a wtb in classifieds thanks cjl Looks like the last person to install the pin got it through the first side, but not the second hole before snapping the clip down. This would allow the force on the pin to apply a torque to only one side of the clevis. |
rgalla9146 |
Jun 8 2015, 07:41 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I think you are fixing the result of another problem.
Very high pedal effort can cause this. Investigate resistance in the clutch cable tube, at the nylon wheel, at the throw out lever, at the throw out bearing sleeve, the throw out bearing and the pressure plate. Also make certain the clutch moves freely on its splines, you know....while you're in there. |
Spoke |
Jun 9 2015, 05:39 PM
Had the same thing happen. Put it back together and used a tiewrap to secure it. That was about two years ago. Still holding.
Lo-Fi Version | Time is now: 14th May 2024 - 12:30 AM |
